If anyone has experience working on appimageTools or skawarePackages, I could use your help with these:
master ← bitbloxhub:push-toluwpstxxsz
opened 07:18PM - 27 Jul 26 UTC
Also migrates away from them with these commands, using ast-grep 0.43.0 with the… se commands in bash (assisted by ChatGPT):
```bash
for old in extractType1 extractType2; do
ast-grep \
--lang nix \
--pattern "\$TOOLS.$old" \
--rewrite '$TOOLS.extract' \
--update-all \
pkgs
done
ast-grep \
--lang nix \
--pattern '$TOOLS.wrapType1' \
--rewrite '$TOOLS.wrapType2' \
--update-all \
pkgs
Assisted-by: GPT-5.6-Sol Medium via ChatGPT
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] aarch64-darwin
- Tested, as applicable:
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
- Nixpkgs Release Notes
- NixOS Release Notes
- [x] Follows the [automation/AI policy].
[automation/AI policy]: https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#automationai-policy
master ← bitbloxhub:push-wppwrvnzslml
opened 07:10PM - 25 Jul 26 UTC
- Forward all attributes to the derivation with `...}@attrs`
- Use `pkg-config… ` (Fixes https://github.com/NixOS/nixpkgs/issues/544293)
- use `placeholder`
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
Both seem pretty good to me, but could use a review from someone with more expertise in these areas.
avhb
July 31, 2026, 6:00am
7321
Hi! I have opened a PR to add the filen (e2e encrypted cloud storage) cli to nix pkgs, there is already a package in nixpkgs for the old nod based implementation, but that one is not being updated anymore, the team has now shifted their effort to the rust based implementation, that is why I propose to publish the package under the filen-cli-rs name. filen-cli-rs: init at 0.2.7 by avhb · Pull Request #545467 · NixOS/nixpkgs · GitHub
Would appreciate to have these two merged as my PR depends on them
master ← Ambossmann:init/python3Packages.openexr
opened 06:19PM - 26 Jul 26 UTC
Adds the officical python wrapper for [`openexr`](https://github.com/AcademySoft… wareFoundation/OpenEXR).
It is necessary to run the the tests of `pillow-jxl-plugin` added in #543307.
Ideally we would just link against the `openexr` already in nixpkgs, but the upstream build process is not designed for that.
I initially created this with `nix-init` and then tweaked it until it worked.
Fixes #277515
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
master ← Ambossmann:init/python3Packages.pyexiv2
opened 06:34PM - 26 Jul 26 UTC
Adds [`pyexiv2`](https://github.com/LeoHsiao1/pyexiv2), a library for reading an… d writing image metadata, based on `exiv2`.
This is different from the python2 package of the same name removed in #141794, `python3Packages.py3exiv2` which is based upon the aforementioned python2 package and also `python3Packages.exiv2`.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
peeley
August 1, 2026, 3:28am
7327
Hello, this PR fixes a long-broken package. Would be very grateful for review!
master ← peeley:fix-am2rlauncher-upgrade-webkitgtk
opened 03:39AM - 24 Jul 26 UTC
This commit also removes the patch to upgrade the dotnet version to 8, as the do… tnet version has now been upgraded upstream.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
- [ ] Follows the [automation/AI policy].
master ← Stebalien:steb/fetchtorrent
opened 12:10AM - 07 Mar 26 UTC
Previously, the flattening logic expected transmission/rqbit to download a direc… tory of files. However, some torrents (ISOs, etc.) download a single file, not wrapped in a directory.
This patch fixes (and tests) that and:
1. Shares logic between rqbit and transmission as much as possible so I don't have to fix this bug twice.
2. Actually emits the rqbit flatten warnings.
3. Disables the tests that now emit warnings due to (2).
4. Makes the Sintel torrent tests to actually exit with a non-zero exit code on hash mismatch.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Tests in [lib/tests] or [pkgs/test] for functions and "core" functionality.
It has several reviews, but it needs someone to verify that the repo-level dotfile changes are good to go.
ntsk
August 3, 2026, 12:16am
7331
Hi! This PR adds a tree-sitter grammar for VCL (Varnish Configuration Language).
Open since May, no review yet. Just rebased and updated to the latest release.
CI is green. Would someone take a look? Thanks!
master ← ntsk:add-tree-sitter-vcl
opened 02:53PM - 07 May 26 UTC
Adds the [tree-sitter grammar](https://github.com/ntsk/tree-sitter-vcl) for VCL … (Varnish Configuration Language).
Grammar source: https://github.com/ntsk/tree-sitter-vcl
Release: https://github.com/ntsk/tree-sitter-vcl/releases/tag/v0.4.0
## Things done
- [x] aarch64-darwin
- [x] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md), [pkgs/README.md](https://github.com/NixOS/nixpkgs/blob/master/pkgs/README.md), [maintainers/README.md](https://github.com/NixOS/nixpkgs/blob/master/maintainers/README.md)
`nixpkgs-review` result on `aarch64-darwin`:
✅ 6 packages built, 0 failed:
- `tree-sitter-grammars.tree-sitter-vcl`
- `python313Packages.tree-sitter-grammars.tree-sitter-vcl` (and `.dist`)
- `python314Packages.tree-sitter-grammars.tree-sitter-vcl` (and `.dist`)
- `diffsitter`
No rush. Just a package to init and also to add myself as a maintainer. Thank you
Pull requests · NixOS/nixpkgs
