Hello,
I have a PR adding a few non-breaking configuration options for systemd-boot entry naming:
PR: https://github.com/NixOS/nixpkgs/pull/516959
I originally added these because my boot entry names were often too long to easily see the generation date. The new options allow shortening/customizing the entry name while preserving the existing behavior by default.
I’ve tested the boot entry generation and added multiple unit tests to cover the new options.
The PR has been open since May and I rebased it after the previous merge conflict, but I’m not sure what the next step should be to get it reviewed.
Thanks!
tetov
August 11, 2026, 5:28pm
7378
master ← tetov:libdjinterop_0_27_1
opened 02:49PM - 29 Jun 26 UTC
Changes: https://github.com/xsco/libdjinterop/compare/0.26.1...0.27.1
Tested … with Mixxx, including an engine export (which uses libdjinterop).
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] aarch64-darwin
- Tested, as applicable:
- [x] [Package tests] at `passthru.tests`.
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
- Nixpkgs Release Notes
- NixOS Release Notes
- [x] Follows the [automation/AI policy].
[automation/AI policy]: https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#automationai-policy
Update to Mixxx dependency. 0.27.1 is required for the Mixxx 2.6 beta, and works on Mixxx 2.5.6.
maxmosk
August 11, 2026, 10:48pm
7379
master ← maxmosk:moskalets/add-grokmirror
opened 11:50AM - 14 May 26 UTC
Framework to smartly mirror git repositories.
## Things done
- B… uilt on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Popular tools for repository sync (mirroring). Still not reviewed
