Thra11
September 27, 2019, 3:32pm
61
I’d appreciate if somebody could review this PR which packages the KDE configuration module for configuring wacom graphics tablets, (although I realise that exhaustively testing it requires a wacom tablet). @tilpner has already pointed out a few issues, which I’ve fixed, so I’m hoping that it might be ready now.
https://github.com/NixOS/nixpkgs/pull/68836
b42
September 28, 2019, 6:13pm
62
Two new NixOS modules.
Sympa, a mailing list manager:
https://github.com/NixOS/nixpkgs/pull/65397
MoinMoin, a wiki engine:
https://github.com/NixOS/nixpkgs/pull/68327
Especially interested in feedback from people who run these services if there are any!
Updates of two spaCy dependencies:
NixOS:master ← danieldk:blis-thinc-update
opened 06:32PM - 29 Aug 19 UTC
###### Motivation for this change
Update the blis and thinc dependencies of s… paCy. Tested using the `en_core_web_sm` model
###### Things done
- [x] Tested using sandboxing ([nix.useSandbox](http://nixos.org/nixos/manual/options.html#opt-nix.useSandbox) on NixOS, or option `sandbox` in [`nix.conf`](http://nixos.org/nix/manual/#sec-conf-file) on non-NixOS)
- Built on platform(s)
- [x] NixOS
- [ ] macOS
- [ ] other Linux distributions
- [ ] Tested via one or more NixOS test(s) if existing and applicable for the change (look inside [nixos/tests](https://github.com/NixOS/nixpkgs/blob/master/nixos/tests))
- [ ] Tested compilation of all pkgs that depend on this change using `nix-shell -p nix-review --run "nix-review wip"`
- [x] Tested execution of all binary files (usually in `./result/bin/`)
- [ ] Determined the impact on package closure size (by running `nix path-info -S` before and after)
- [ ] Ensured that relevant documentation is up to date
- [x] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/.github/CONTRIBUTING.md).
###### Notify maintainers
cc @
Basically version + hash bumps, plus the necessary version constraint relaxations necessary in spaCy itself.
I would like an additional review on this one, just to be safe:
NixOS:master ← Lassulus:loopback
opened 03:26PM - 21 Sep 19 UTC
this feature was requested here: https://gi… thub.com/NixOS/nixpkgs/issues/67627
###### Things done
- [ ] Tested using sandboxing ([nix.useSandbox](http://nixos.org/nixos/manual/options.html#opt-nix.useSandbox) on NixOS, or option `sandbox` in [`nix.conf`](http://nixos.org/nix/manual/#sec-conf-file) on non-NixOS)
- [ ] NixOS
- [ ] macOS
- [ ] Tested execution of all binary files (usually in `./result/bin/`)
- [ ] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/.github/CONTRIBUTING.md).
cc @
smaret
October 6, 2019, 7:29pm
65
Can someone have a look at this PR please? It’s a simple update of one of the packages I maintain.
NixOS:master ← smaret:gildas-20191001_a
opened 08:58AM - 01 Oct 19 UTC
Update gildas to the latest usptream.
##… #### Things done
- [ ] NixOS
- [x] macOS
- [x] other Linux distributions
- [x] Tested compilation of all pkgs that depend on this change using `nix-shell -p nix-review --run "nix-review wip"`
moaxcp
October 7, 2019, 10:47am
66
Hello, I add two new packages
https://github.com/NixOS/nixpkgs/pull/70282
NixOS:master ← moaxcp:asciidoctorj
opened 10:09AM - 07 Oct 19 UTC
Add asciidoctorj package
###### Things d… one
- [x] NixOS
- [ ] macOS
cc @
If you put the links on their own line then discourse will make them look nicer
I’m looking for any httpd users on NixOS to compare their httpd.conf file generated by this PR to what is currently generated by NixOS. I would also appreciate any review of the nix code in this PR as the httpd module code is overly complicated - a second and third pair of eyes looking at the changes in depth would be appreciated, even by people who aren’t familiar with httpd but have strong nix lang skills.
NixOS:master ← aanderse:httpd
opened 01:49AM - 13 Oct 19 UTC
Cleaning up the `httpd` module.
I would ap… preciate the efforts of any `httpd` users who would run their configuration through this branch, compare the generated `httpd.conf` to their own, and then share the results.
###### Things done
I have compared several `httpd` configuration files generated by this new build compared to what `19.09` builds and they are pretty much identical.
- [x] NixOS
- [ ] macOS
- [x] Tested via one or more NixOS test(s) if existing and applicable for the change (look inside [nixos/tests](https://github.com/NixOS/nixpkgs/blob/master/nixos/tests))
- [x] Ensured that relevant documentation is up to date
cc @
I’ve had a PR open for 2.5 months that rewrites stripHash
https://github.com/NixOS/nixpkgs/pull/66161
This fixes a bug wherein stripHash --foo doesn’t treat --foo as a filename, and also massively improves performance in the process. The only problem is I’m not willing to rebuild the world on my machine, so I haven’t built any packages with this change, only tested in isolation on all inputs I can think of. It is targeting staging though.
asbachb
October 20, 2019, 10:54pm
70
bbigras
October 30, 2019, 4:47pm
72
Not my PR. I reviewed it but the 2 maintainers don’t seem to have the time right now and we could use some extra pairs of eyes and someone to merge it.
~~https://github.com/NixOS/nixpkgs/pull/69962~~
I’ve got a MacVim update
~~https://github.com/NixOS/nixpkgs/pull/71380~~
This has been sitting around for almost 2 weeks, long enough that I’ve actually just updated it for yet another MacVim version.
ckampka
November 1, 2019, 9:48am
74
https://github.com/NixOS/nixpkgs/pull/71083
This PR has been around for 19 days now without a single comment.
Every new test in nixpkgs means I have to touch this again to get it to merge so I would really appreciate a review soon-ish.
My MacVim update (see previous comment) is still pending.
I’ve also got a cocoapods update that’s over a month old at this point.
~~https://github.com/NixOS/nixpkgs/pull/70417~~
ckampka
November 7, 2019, 10:28am
76
https://github.com/NixOS/nixpkgs/pull/71226
This commit needs a review from an experienced Go build system reviewer.
The hash of the gomods keeps changing for ofBorg, sometimes even during the same build run (eg. OK for x64_86, not ok for Darwin).
https://github.com/NixOS/nixpkgs/pull/70306
This PR has seen no activity since I submitted it a month ago. It’s really a simple change – it adds spaCy models for Norwegian and Lithuanian. What is mostly needed: test if it builds, test if the model loads.
cko
November 7, 2019, 11:26pm
78
https://github.com/NixOS/nixpkgs/pull/70941
Version update, metadata addition, etc. for hsqldb a small relational dabase management system.
cko
November 10, 2019, 8:37am
79
rnhmjoj
November 10, 2019, 10:23pm
80
It’s been a while since I submitted this: nixos: unify virtual console options by rnhmjoj · Pull Request #71473 · NixOS/nixpkgs · GitHub .
I’m trying to reorganize the options about virtual console and I’d like to hear some opinions.
