PRs ready for review _
https://github.com/NixOS/nixpkgs/pull/164698
Bumps
~~https://github.com/NixOS/nixpkgs/pull/171398~~
~~https://github.com/NixOS/nixpkgs/pull/171536~~
~~https://github.com/NixOS/nixpkgs/pull/170726~~
~~https://github.com/NixOS/nixpkgs/pull/170019~~
https://github.com/NixOS/nixpkgs/pull/169302#issuecomment-1102509632
https://github.com/NixOS/nixpkgs/pull/171143
https://github.com/NixOS/nixpkgs/pull/170851
https://github.com/NixOS/nixpkgs/pull/171160
https://github.com/NixOS/nixpkgs/pull/169175
https://github.com/NixOS/nixpkgs/pull/170901
~~https://github.com/NixOS/nixpkgs/pull/171550~~
~~https://github.com/NixOS/nixpkgs/pull/171862~~
https://github.com/NixOS/nixpkgs/pull/171022
https://github.com/NixOS/nixpkgs/pull/172076
https://github.com/NixOS/nixpkgs/pull/171949
Would be great to get this major version bump into 22.05. Mostly ready to go, just bikeshedding the approach for failing unit tests.
https://github.com/NixOS/nixpkgs/pull/171165
If somebody who is on darwin/x86_64 could just check out this PR:
https://github.com/NixOS/nixpkgs/pull/147486
And run the GUI with nix-build -A crystfel && result/bin/crystfel to check if it really runs and not just compiles, that would be very nice. I only have a Linux machine here unfortunately…
This helps users avoid creating potentially dangerous configuration when using the recently introduced 1Password module. It would be great if this made it into 22.05 before the 1Password module hits NixOS stable.
https://github.com/NixOS/nixpkgs/pull/172058
https://github.com/NixOS/nixpkgs/pull/168222
node2nix might make it controversial, could be changed to just pulling the compiled release instead of compiling it with node2nix from source.
https://github.com/NixOS/nixpkgs/pull/173006
https://github.com/NixOS/nixpkgs/pull/172302
https://github.com/NixOS/nixpkgs/pull/171766
fixes:
https://github.com/NixOS/nixpkgs/issues/171138
