Majiir
November 2, 2022, 3:46am
1344
B4rc1
November 3, 2022, 12:09am
1346
henkery
November 3, 2022, 7:57am
1349
wegank
November 4, 2022, 9:12pm
1352
tni
November 5, 2022, 8:18am
1354
NixOS:master ← tjni:fix-pdoc3
opened 10:07AM - 30 Oct 22 UTC
###### Description of changes
Pull in https://github.com/pdoc3/pdoc/pull/414,… which fixes https://github.com/pdoc3/pdoc/issues/400.
###### Things done
- Built on platform(s)
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] aarch64-darwin
- [ ] Tested, as applicable:
- [22.11 Release Notes (or backporting 22.05 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2211-release-notes)
- [ ] (Release notes changes) Ran `nixos/doc/manual/md-to-db.sh` to update generated release notes
Thanks a lot if you do!
https://github.com/NixOS/nixpkgs/pull/198817
thyol
November 6, 2022, 10:30am
1355
Enzime
November 6, 2022, 11:51am
1357
I’ve just refreshed this stale branch with Erlang 25.1.2 instead. No reviewers were auto-tagged and I don’t know if there is anything I can or should have done differently as an individual to receive reviews, so advice is welcome.
https://github.com/NixOS/nixpkgs/pull/196785
Yarny
November 6, 2022, 7:05pm
1362
This is just a fallout from the libxcrypt migration
https://github.com/NixOS/nixpkgs/pull/198830
Would be cool to have this merged before the branch-off to have a working tsm-client in the next release.
Luflosi
November 6, 2022, 7:34pm
1363
zendo
November 6, 2022, 9:06pm
1364
vs49688
November 7, 2022, 4:29am
1367
If I may:
NixOS:staging ← vs49688:miniffmpeg-staging
opened 01:52AM - 23 Oct 22 UTC
Following on from https://github.com/NixOS/nixpkg… s/pull/196263. Now that we have `ffmpeg-headless`, use it!
Specifically, we can now cleanup `ffmpeg` override for `pipewire`.
###### Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
Relatively small PR, but needs a lot of rebuilds.
