tni
November 28, 2022, 9:43pm
1482
urandom
November 29, 2022, 10:24am
1483
https://github.com/NixOS/nixpkgs/pull/203582
https://github.com/NixOS/nixpkgs/pull/203179
https://github.com/NixOS/nixpkgs/pull/203020
https://github.com/NixOS/nixpkgs/pull/203017
https://github.com/NixOS/nixpkgs/pull/202978
https://github.com/NixOS/nixpkgs/pull/200179
https://github.com/NixOS/nixpkgs/pull/200157
https://github.com/NixOS/nixpkgs/pull/200148
https://github.com/NixOS/nixpkgs/pull/199592
NixOS:master ← urandom2:mgmt
opened 02:25PM - 01 Nov 22 UTC
###### Description of changes
This change adds two packages: mgmt and nex. Th… e latter is a build dependency for the former. Unfortunately both do not have stable releases, thus each tracks the tip of their respective upstream branches. Go module pseudo versions are used.
mgmt: Next generation distributed, event-driven, parallel config management!
nex: Lexer for Go
Fixes #98458 purpleidea/mgmt#610
###### Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [x] Tested, as applicable:
- [22.11 Release Notes (or backporting 22.05 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2211-release-notes)
- [ ] (Release notes changes) Ran `nixos/doc/manual/md-to-db.sh` to update generated release notes
Thanks a lot if you do!
djm
November 29, 2022, 10:39am
1484
leungbk
November 29, 2022, 11:02am
1485
Sandro
November 29, 2022, 12:37pm
1486
You do not need to repost the same PRs every few days. People usually get back to you in a few days. If they are obviously got lost and things didn’t move for the last week or more than it is totally fine to repost them.
New PR, partially reviewed by a maintainer of a very similar app.
https://github.com/NixOS/nixpkgs/pull/203487
urandom
November 29, 2022, 8:00pm
1488
terribly sorry; there was not really any description of how to use this thread, and I was just bumping anything that had been updated and needed further review, but I am happy to wait at least a week before reposting.
gador
November 30, 2022, 10:03am
1491
Mats
December 1, 2022, 7:52pm
1494
Polaris
December 2, 2022, 3:00am
1497
djm
December 2, 2022, 5:56am
1498
urandom
December 3, 2022, 12:39am
1500
djm
December 3, 2022, 4:38pm
1501
