Congee
December 24, 2022, 3:55am
1593
Dear Santa,
please consider reviewing if not merging the following PRs which some of your elves already took a look at before:
https://github.com/NixOS/nixpkgs/pull/204145
https://github.com/NixOS/nixpkgs/pull/203449
YourFin
December 24, 2022, 7:48pm
1595
I have two 9 day old updates for two gnu packages that I would really appreciate a review on! I tried to clean their builds up a little while I was at it
https://github.com/NixOS/nixpkgs/pull/206300
https://github.com/NixOS/nixpkgs/pull/206317
romildo
December 24, 2022, 9:01pm
1596
zarel
December 25, 2022, 7:54pm
1598
There is a new nixos test that would cover both existing and new features.
https://github.com/NixOS/nixpkgs/pull/205653
mlyxshi
December 26, 2022, 7:58am
1600
andersk
December 26, 2022, 8:58pm
1604
urandom
December 26, 2022, 11:40pm
1605
NixOS:master β urandom2:mgmt
opened 02:25PM - 01 Nov 22 UTC
###### Description of changes
This change adds two packages: mgmt and nex. Th⦠e latter is a build dependency for the former. Unfortunately both do not have stable releases, thus each tracks the tip of their respective upstream branches. Go module pseudo versions are used.
mgmt: Next generation distributed, event-driven, parallel config management!
nex: Lexer for Go
Fixes #98458 purpleidea/mgmt#610
###### Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [x] Tested, as applicable:
- [22.11 Release Notes (or backporting 22.05 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2211-release-notes)
- [ ] (Release notes changes) Ran `nixos/doc/manual/md-to-db.sh` to update generated release notes
Thanks a lot if you do!
https://github.com/NixOS/nixpkgs/pull/202978
https://github.com/NixOS/nixpkgs/pull/203017
https://github.com/NixOS/nixpkgs/pull/203020
https://github.com/NixOS/nixpkgs/pull/203582
https://github.com/NixOS/nixpkgs/pull/203904
https://github.com/NixOS/nixpkgs/pull/203905
https://github.com/NixOS/nixpkgs/pull/203932
https://github.com/NixOS/nixpkgs/pull/207884
milahu
December 27, 2022, 8:21am
1606
henkery
December 27, 2022, 7:27pm
1608
urandom
December 28, 2022, 12:13am
1609
hraban
December 28, 2022, 9:28am
1610
Adding support for fetching by commit hash in Darcs, like the git fetcher.
https://github.com/NixOS/nixpkgs/pull/205115
Iβm using this in another feature branch which isnβt in master, but it seemed like a sensible patch to mainline?
azuwis
December 28, 2022, 2:41pm
1612
Sweenu
December 28, 2022, 4:12pm
1613
