For a development project, I need the Beta for pygame2. I tried to install it using virtualenv, which works, but at runtime I get the following error:
$ python
Python 3.7.6 (default, Dec 18 2019, 19:23:55)
[GCC 9.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import pygame
pygame 2.0.0.dev8 (SDL 2.0.12, python 3.7.6)
Hello from the pygame community. https://www.pygame.org/contribute.html
>>> pygame.display.init()
File "<stdin>", line 1, in <module>
pygame.error: No available video device
I assume it has something to do with SDL2 not finding the x libraries or something like this, but I don’t know how to tackle this problem properly. I also tried it with pygame1.9.6 with the same result.
@AberDerBart - did you ever solve this issue?
I’m now facing the same situation trying to setup a development environment and am curious how to let SDL2 find the libraries it needs.
I installed pygame via shell.nix and used pip for the rest:
unstable = import <nixos-unstable> {};
in pkgs.mkShell {
buildInputs = [
unstable.python3
unstable.python3Packages.pip
unstable.python3Packages.pygame
shellHook = ''
alias pip="PIP_PREFIX='$(pwd)/_build/pip_packages' \pip"
export PYTHONPATH="$(pwd)/_build/pip_packages/lib/python3.7/site-packages:$PYTHONPATH"
unset SOURCE_DATE_EPOCH
It’s not the prettiest solution, but it worked for me. It would probably be better to install all packages via shell.nix
Thanks - I ended up using the packaged version, too, though I was able to use mach-nix to keep everything declarative (so far…I’m still working to get ray[rllib] working).
mach-nix = import (
builtins.fetchGit {
url = "https://github.com/DavHau/mach-nix/";
ref = "refs/tags/3.3.0";
custom-python = mach-nix.mkPython {
python = "python38Full";
requirements = ''
griddly
matplotlib
providers = {
_default = "wheel,sdist,nixpkgs";
with pkgs;
mkShell {
buildInputs = [
custom-python
python38Packages.pygame # Nixpkgs fixes up some complexities
python38Packages.pytorch # Nixpkgs fixes up some complexities
vulkan-loader # Griddly needs the Vulkan-SDK
LD_LIBRARY_PATH="${vulkan-loader}/lib";
