I have a python3.pkgs.buildPythonApplication
derivation that specifies a bunch of python packages in propagatedBuildInputs
propagatedBuildInputs = with python3.pkgs; [
# [others removed for brevity]
cx_Freeze
packaging
When the build gets to the pipInstallPhase
, I get an error about cx_Freeze
not finding packaging>=21.0
Executing pipInstallPhase
/build/cx_Freeze-6.11.1/dist /build/cx_Freeze-6.11.1
Processing ./cx_Freeze-6.11.1-cp310-cp310-linux_x86_64.whl
ERROR: Could not find a version that satisfies the requirement packaging>=21.0 (from cx-freeze) (from versions: none)
ERROR: No matching distribution found for packaging>=21.0
Even though python3.pkgs.packaging.version
is 21.3
$ nix repl .
Welcome to Nix 2.8.1. Type :? for help.
Loading '.'...
Added 17165 variables.
nix-repl> :p python3.pkgs.packaging.version
"21.3"
How is this requirement not satisfied?
Full derivation: https://github.com/aidalgol/nixpkgs/blob/742318d8b1230004a94685beb5d0a596aa955d42/pkgs/applications/misc/meshroom/default.nix
Full nix log
Sourcing python-remove-tests-dir-hook
Sourcing python-catch-conflicts-hook.sh
Sourcing python-remove-bin-bytecode-hook.sh
Sourcing setuptools-build-hook
Using setuptoolsBuildPhase
Using setuptoolsShellHook
Sourcing pip-install-hook
Using pipInstallPhase
Sourcing python-imports-check-hook.sh
Using pythonImportsCheckPhase
Sourcing python-namespaces-hook
@nix { "action": "setPhase", "phase": "unpackPhase" }
unpacking sources
unpacking source archive /nix/store/7isqnggx2cpwrd2jlnw9rdrn1bmkdahs-cx_Freeze-6.11.1.tar.gz
source root is cx_Freeze-6.11.1
setting SOURCE_DATE_EPOCH to timestamp 1655871207 of file cx_Freeze-6.11.1/setup.cfg
@nix { "action": "setPhase", "phase": "patchPhase" }
patching sources
substituteStream(): WARNING: pattern 'os.stat(module.file).st_mtime' doesn't match anything in file 'cx_Freeze/freezer.py'
@nix { "action": "setPhase", "phase": "configurePhase" }
configuring
@nix { "action": "setPhase", "phase": "buildPhase" }
building
Executing setuptoolsBuildPhase
/nix/store/1pxd3xyarxfr6bxrkz2px70j59pa4z04-python3.10-setuptools-63.2.0/lib/python3.10/site-packages/setuptools/config/setupcfg.py:463: SetuptoolsDeprecationWarning: The license_file parameter is deprecated, use license_files instead.
warnings.warn(msg, warning_class)
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-cpython-310
creating build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/module.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/parser.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/common.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/winversioninfo.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/finder.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/cli.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/exception.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/_compat.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/__main__.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/hooks.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/winmsvcr.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/sandbox.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/darwintools.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/freezer.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/dist.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/executable.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/setupwriter.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
copying cx_Freeze/__init__.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze
creating build/lib.linux-x86_64-cpython-310/cx_Freeze/command
copying cx_Freeze/command/build_exe.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/command
copying cx_Freeze/command/install_exe.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/command
copying cx_Freeze/command/build.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/command
copying cx_Freeze/command/__init__.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/command
copying cx_Freeze/command/bdist_mac.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/command
copying cx_Freeze/command/_pydialog.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/command
copying cx_Freeze/command/bdist_msi.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/command
copying cx_Freeze/command/install.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/command
copying cx_Freeze/command/bdist_rpm.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/command
copying cx_Freeze/command/_bdist_msi.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/command
creating build/lib.linux-x86_64-cpython-310/cx_Freeze/initscripts
copying cx_Freeze/initscripts/SharedLibSource.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/initscripts
copying cx_Freeze/initscripts/ConsoleSetLibPath.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/initscripts
copying cx_Freeze/initscripts/SharedLib.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/initscripts
copying cx_Freeze/initscripts/__startup__.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/initscripts
copying cx_Freeze/initscripts/Console.py -> build/lib.linux-x86_64-cpython-310/cx_Freeze/initscripts
running build_ext
running install_include
/nix/store/1pxd3xyarxfr6bxrkz2px70j59pa4z04-python3.10-setuptools-63.2.0/lib/python3.10/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
creating build/temp.linux-x86_64-cpython-310
creating build/temp.linux-x86_64-cpython-310/source
creating build/temp.linux-x86_64-cpython-310/source/bases
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -I/nix/store/c1vb2z3c64i0sd92iz7fv0lb720qcvhb-python3-3.10.6/include/python3.10 -c source/bases/Console.c -o build/temp.linux-x86_64-cpython-310/source/bases/Console.o
creating build/lib.linux-x86_64-cpython-310/cx_Freeze/bases
gcc build/temp.linux-x86_64-cpython-310/source/bases/Console.o -L/nix/store/c1vb2z3c64i0sd92iz7fv0lb720qcvhb-python3-3.10.6/lib/python3.10/config-3.10-x86_64-linux-gnu -L/nix/store/c1vb2z3c64i0sd92iz7fv0lb720qcvhb-python3-3.10.6/lib -lpython3.10 -o build/lib.linux-x86_64-cpython-310/cx_Freeze/bases/Console-cpython-310-x86_64-linux-gnu -Xlinker -export-dynamic -ldl -lcrypt -lm -lm -s -Wl,-rpath,$ORIGIN/lib -Wl,-rpath,$ORIGIN/../lib
installing to build/bdist.linux-x86_64/wheel
running install
running install_lib
creating build/bdist.linux-x86_64
creating build/bdist.linux-x86_64/wheel
creating build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/__init__.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/dist.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/hooks.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/setupwriter.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
creating build/bdist.linux-x86_64/wheel/cx_Freeze/initscripts
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/initscripts/ConsoleSetLibPath.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/initscripts
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/initscripts/SharedLib.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/initscripts
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/initscripts/SharedLibSource.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/initscripts
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/initscripts/Console.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/initscripts
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/initscripts/__startup__.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/initscripts
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/executable.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/_compat.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/cli.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/darwintools.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/winmsvcr.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/exception.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
creating build/bdist.linux-x86_64/wheel/cx_Freeze/bases
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/bases/Console-cpython-310-x86_64-linux-gnu -> build/bdist.linux-x86_64/wheel/cx_Freeze/bases
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/common.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
creating build/bdist.linux-x86_64/wheel/cx_Freeze/command
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/command/_pydialog.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/command
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/command/build.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/command
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/command/install.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/command
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/command/bdist_msi.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/command
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/command/__init__.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/command
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/command/bdist_rpm.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/command
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/command/install_exe.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/command
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/command/_bdist_msi.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/command
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/command/build_exe.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/command
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/command/bdist_mac.py -> build/bdist.linux-x86_64/wheel/cx_Freeze/command
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/finder.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/winversioninfo.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/__main__.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/sandbox.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/parser.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/module.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
copying build/lib.linux-x86_64-cpython-310/cx_Freeze/freezer.py -> build/bdist.linux-x86_64/wheel/cx_Freeze
writing byte-compilation script '/build/tmp_1oekh2l.py'
/nix/store/c1vb2z3c64i0sd92iz7fv0lb720qcvhb-python3-3.10.6/bin/python3.10 /build/tmp_1oekh2l.py
/build/tmp_1oekh2l.py:1: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
from distutils.util import byte_compile
removing /build/tmp_1oekh2l.py
running install_egg_info
running egg_info
writing cx_Freeze.egg-info/PKG-INFO
writing dependency_links to cx_Freeze.egg-info/dependency_links.txt
writing entry points to cx_Freeze.egg-info/entry_points.txt
writing requirements to cx_Freeze.egg-info/requires.txt
writing top-level names to cx_Freeze.egg-info/top_level.txt
reading manifest file 'cx_Freeze.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
adding license file 'doc/src/license.rst'
writing manifest file 'cx_Freeze.egg-info/SOURCES.txt'
Copying cx_Freeze.egg-info to build/bdist.linux-x86_64/wheel/cx_Freeze-6.11.1-py3.10.egg-info
running install_scripts
creating build/bdist.linux-x86_64/wheel/cx_Freeze-6.11.1.dist-info/WHEEL
creating 'dist/cx_Freeze-6.11.1-cp310-cp310-linux_x86_64.whl' and adding 'build/bdist.linux-x86_64/wheel' to it
adding 'cx_Freeze/__init__.py'
adding 'cx_Freeze/__main__.py'
adding 'cx_Freeze/_compat.py'
adding 'cx_Freeze/cli.py'
adding 'cx_Freeze/common.py'
adding 'cx_Freeze/darwintools.py'
adding 'cx_Freeze/dist.py'
adding 'cx_Freeze/exception.py'
adding 'cx_Freeze/executable.py'
adding 'cx_Freeze/finder.py'
adding 'cx_Freeze/freezer.py'
adding 'cx_Freeze/hooks.py'
adding 'cx_Freeze/module.py'
adding 'cx_Freeze/parser.py'
adding 'cx_Freeze/sandbox.py'
adding 'cx_Freeze/setupwriter.py'
adding 'cx_Freeze/winmsvcr.py'
adding 'cx_Freeze/winversioninfo.py'
adding 'cx_Freeze/__pycache__/__init__.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/__main__.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/_compat.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/cli.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/common.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/darwintools.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/dist.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/exception.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/executable.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/finder.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/freezer.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/hooks.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/module.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/parser.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/sandbox.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/setupwriter.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/winmsvcr.cpython-310.opt-1.pyc'
adding 'cx_Freeze/__pycache__/winversioninfo.cpython-310.opt-1.pyc'
adding 'cx_Freeze/bases/Console-cpython-310-x86_64-linux-gnu'
adding 'cx_Freeze/command/__init__.py'
adding 'cx_Freeze/command/_bdist_msi.py'
adding 'cx_Freeze/command/_pydialog.py'
adding 'cx_Freeze/command/bdist_mac.py'
adding 'cx_Freeze/command/bdist_msi.py'
adding 'cx_Freeze/command/bdist_rpm.py'
adding 'cx_Freeze/command/build.py'
adding 'cx_Freeze/command/build_exe.py'
adding 'cx_Freeze/command/install.py'
adding 'cx_Freeze/command/install_exe.py'
adding 'cx_Freeze/command/__pycache__/__init__.cpython-310.opt-1.pyc'
adding 'cx_Freeze/command/__pycache__/_bdist_msi.cpython-310.opt-1.pyc'
adding 'cx_Freeze/command/__pycache__/_pydialog.cpython-310.opt-1.pyc'
adding 'cx_Freeze/command/__pycache__/bdist_mac.cpython-310.opt-1.pyc'
adding 'cx_Freeze/command/__pycache__/bdist_msi.cpython-310.opt-1.pyc'
adding 'cx_Freeze/command/__pycache__/bdist_rpm.cpython-310.opt-1.pyc'
adding 'cx_Freeze/command/__pycache__/build.cpython-310.opt-1.pyc'
adding 'cx_Freeze/command/__pycache__/build_exe.cpython-310.opt-1.pyc'
adding 'cx_Freeze/command/__pycache__/install.cpython-310.opt-1.pyc'
adding 'cx_Freeze/command/__pycache__/install_exe.cpython-310.opt-1.pyc'
adding 'cx_Freeze/initscripts/Console.py'
adding 'cx_Freeze/initscripts/ConsoleSetLibPath.py'
adding 'cx_Freeze/initscripts/SharedLib.py'
adding 'cx_Freeze/initscripts/SharedLibSource.py'
adding 'cx_Freeze/initscripts/__startup__.py'
adding 'cx_Freeze/initscripts/__pycache__/Console.cpython-310.opt-1.pyc'
adding 'cx_Freeze/initscripts/__pycache__/ConsoleSetLibPath.cpython-310.opt-1.pyc'
adding 'cx_Freeze/initscripts/__pycache__/SharedLib.cpython-310.opt-1.pyc'
adding 'cx_Freeze/initscripts/__pycache__/SharedLibSource.cpython-310.opt-1.pyc'
adding 'cx_Freeze/initscripts/__pycache__/__startup__.cpython-310.opt-1.pyc'
adding 'cx_Freeze-6.11.1.dist-info/METADATA'
adding 'cx_Freeze-6.11.1.dist-info/WHEEL'
adding 'cx_Freeze-6.11.1.dist-info/entry_points.txt'
adding 'cx_Freeze-6.11.1.dist-info/license.rst'
adding 'cx_Freeze-6.11.1.dist-info/top_level.txt'
adding 'cx_Freeze-6.11.1.dist-info/RECORD'
removing build/bdist.linux-x86_64/wheel
Finished executing setuptoolsBuildPhase
buildPhase completed in 1 minutes 8 seconds
@nix { "action": "setPhase", "phase": "installPhase" }
installing
