Python Package Wheel No matching distribution found
Hi!
I’m trying to packaging GitHub - nfstream/nfstream: NFStream: a Flexible Network Data Analysis Framework.
nfstream · PyPI
But i get those errors:
  /nix/store/b5v15x6w83xvayfprmzvdhqanz05c53z-nfstream-6.3.5.drv
building '/nix/store/b5v15x6w83xvayfprmzvdhqanz05c53z-nfstream-6.3.5.drv'...
Sourcing python-remove-tests-dir-hook
Sourcing python-catch-conflicts-hook.sh
Sourcing python-remove-bin-bytecode-hook.sh
Sourcing wheel setup hook
Using wheelUnpackPhase
Sourcing pip-install-hook
Using pipInstallPhase
Sourcing python-imports-check-hook.sh
Using pythonImportsCheckPhase
Sourcing python-namespaces-hook
unpacking sources
Executing wheelUnpackPhase
Finished executing wheelUnpackPhase
patching sources
configuring
building
no Makefile, doing nothing
installing
Executing pipInstallPhase
/build/dist /build
Processing ./nfstream-6.3.5-cp39-cp39-manylinux1_x86_64.whl
ERROR: Could not find a version that satisfies the requirement psutil>=5.8.0 (from nfstream)
ERROR: No matching distribution found for psutil>=5.8.0
error: builder for '/nix/store/b5v15x6w83xvayfprmzvdhqanz05c53z-nfstream-6.3.5.drv' failed with exit code 1;
       last 10 log lines:
       > configuring
       > building
       > installing
       > /build/dist /build
       For full logs, run 'nix log /nix/store/b5v15x6w83xvayfprmzvdhqanz05c53z-nfstream-6.3.5.drv'.
with the following derivation:
with import <nixos-unstable> {};
with python39Packages;
assert (isPy39 || isPy38 || isPy37 || isPy36);
let urls = {
      "6.3.5" = {
        py36 = {
          url = https://files.pythonhosted.org/packages/22/c5/9159521b70d70520a66fcf6554d0d22744bfdb602dc9f3adaa8c6e5cbeb6/nfstream-6.3.5-cp36-cp36m-manylinux1_x86_64.whl;
          sha256 = "1qs8rrjaplw29gpgq4348y88nm9hfr0mn9hjak3sk4j8qikbi211";
        py37 = {
          url = https://files.pythonhosted.org/packages/15/19/6fe2b23a85ddf45f689a82133605edd8e6ec908da64d0e5692c4921daa2f/nfstream-6.3.5-cp37-cp37m-manylinux1_x86_64.whl;
          sha256 = "1350hlyqv1lrvy4qc3i9lvwacx50vzqpcnjf9rqhn8zccs7rpmdz";
        py38 = {
          url = https://files.pythonhosted.org/packages/19/fb/e722fe1aaf66259ce7e038362935dae948d1038744a6eb344cce92eeceb6/nfstream-6.3.5-cp38-cp38-manylinux1_x86_64.whl;
          sha256 = "0x0xbsjg5gb34dshzs5vp4f8ljk6wc4p63pw7728dnl2ashly2hz";
        py39 = {
          url = https://files.pythonhosted.org/packages/b7/90/d70d47c166b6a6cf0d386e62e727276ff6b8824633432f59f10ff640e9f0/nfstream-6.3.5-cp39-cp39-manylinux1_x86_64.whl;
          sha256 = "1wqcz4vavay56gf8nn55s67wp61rmyw8s1mzki3b3zbbzwl1zbvy";
      "6.3.4" = {
        py36 = {
          url = https://files.pythonhosted.org/packages/cc/3a/e0058dcdb991d9730b2c1054d601105b9c5abdff1090f477af295f0129d4/nfstream-6.3.4-pp36-pypy36_pp73-manylinux1_x86_64.whl;
          sha256 = "02qcqv4m2wjhfwis09i20b5drgvas22njrmk4jihc0ybm131m7dr";
        py37 = {
          url = https://files.pythonhosted.org/packages/7d/42/1c3fefa074fb506f778ab007d35e323f3c5ebd587e9c7183a497ac830825/nfstream-6.3.4-pp37-pypy37_pp73-manylinux1_x86_64.whl;
          sha256 = "1f3d5imnaajl74lbqf8grxk0bbb73j6zrbvajxfmyd6b56l4m4cd";
buildPythonApplication rec {
  pname = "nfstream";
  version = "6.3.5";
  format = "wheel";
  src = builtins.fetchurl (with urls."${version}"; if isPy36 then py36 else if isPy37 then py37 else if isPy38 then py38 else py39);
  buildInputs = [ libgpgerror libgcrypt libpcap ndpi ];
  propagatedBuildInputs = [ setuptools ];
  nativeBuildInputs = [ autoPatchelfHook ];
  meta = with lib; {
    description = "Python Framework for network data analytics";
    homepage = "https://github.com/nfstream/nfstream";
    license = licenses.lgpl3;
    maintainers = with maintainers; [ heph2 ];
Any ideas?
psutil is a runtime dependency. Adding it to propagatedBuildInputs should do the trick if I’m not missing something.
i’ve added psutil to “propagatedBuildInputs” and now i got this error
Requirement already satisfied: psutil>=5.8.0 in /nix/store/9j2pzpxpr5w9r20vc4zrrzllqmy4mssk-python3.9-psutil-5.8.0/lib/python3.9/site-packages (from nfstream==6.3.5) (5.8.0)
ERROR: Could not find a version that satisfies the requirement dpkt>=1.9.7 (from nfstream)
ERROR: No matching distribution found for dpkt>=1.9.7
error: builder for '/nix/store/3dxq3ryb7a6i6sl15q3xd3zc7w5y26bd-nfstream-6.3.5.drv' failed with exit code 1;
       last 10 log lines:
       > building
       > installing
       > /build/dist /build
       For full logs, run 'nix log /nix/store/3dxq3ryb7a6i6sl15q3xd3zc7w5y26bd-nfstream-6.3.5.drv'.
But AFAIK in the unstable channel dpkt is 1.9.7…
Have you added it to to the propagatedBuildInputs as well? also i don’t think that adding setuptools to that list is the right thing to do if it’s imported only in the setup.py
That’s the first time that i try to packaging a python lib…
What should i do exactly?
ps: still error with dpkt, seems like it’s not using the unstable channel
can you publish your work somewhere? That way it would be much simpler for us to help you out
If pure-python packages aren’t packaged on nixpkgs, then you can use nixpkgs/python.section.md at f790fcd0bea2ef09f436e9d8088cfe2fea2c4c12 · NixOS/nixpkgs · GitHub to use venv+nix to create a dev environment.
If you want a pure nix-environment, then you’ll need to package the missing dependencies, or use a tool like mach2nix, poetry2nix, or something similar to “bridge the gap”.
dpkt at least exists on nixpkgs master:
nix-repl> python3Packages.dpkt
«derivation /nix/store/39z4vi75ysffmirr6nklkg30pgffz1mj-python3.9-dpkt-1.9.7.2.drv»
Looking at the upstream repo, it looks like it should be pretty easy to build without resorting to wheels. I would just build it from source.
I’ve publish the current derivation here:
http://gist.mrkeebs.eu/#org774c8ad
I’m not that familiar with python and also with Nix, so my attempt to packaging usually are a bit of a mess…
I’ve tried without wheels and found this error:
/build/dist /build
ERROR: You must give at least one requirement to install (see "pip help install")
error: builder for '/nix/store/zg57m67vvqfycg1prpkwxjsmjasv7hg5-nfstream-6.3.5.drv' failed with exit code 1;
       last 10 log lines:
       > patching sources
       > configuring
       > building
       > installing
       > /build/dist /build
       For full logs, run 'nix log /nix/store/zg57m67vvqfycg1prpkwxjsmjasv7hg5-nfstream-6.3.5.drv'.
I’ve published what i wrote above :smiley:
“server gist.mrkeebs.eu is taking too long too respond” Port closed?
Mmm sorry, for some strange reason my DDNS script didn’t update my DNS :smiley:
Now should be reachable
Ok, @heph I did some more steps with this:
  pkgs = import <nixos-unstable> {};
  inherit (pkgs) python39Packages fetchFromGitHub lib;
  inherit (python39Packages) buildPythonApplication;
in buildPythonApplication {
  pname = "nfstream";
  version = "6.3.5";
  src = fetchFromGitHub {
    owner = "nfstream";
    repo = "nfstream";
    rev = "v6.3.5";
    sha256 = "HamSYEaCJ3z32YipjcNGwsvBxababm8OYEMM2tmdZ3A=";
  buildInputs = with pkgs; [ libgpgerror libgcrypt libpcap ndpi ];
  propagatedBuildInputs = with python39Packages; [ psutil numpy dpkt cffi pandas ];
  meta = with lib; {
Now it tries to build but fails because of some hardcoded paths in nfstream/setup.py at 6d402b9435e5f8e3284ab026ac87f18a0aeea375 · nfstream/nfstream · GitHub
You will have to patch it with the right ones from the store
Oh thanks :smiley:
I got this error in one of my attempts, but didn’t understand the cause…
So… How should i patch them from nix?
this is how I do patches: Nixpkgs - How to create a patch for any package - YouTube
I went a bit further with this:
  pkgs = import <nixpkgs> {};
  inherit (pkgs) python39Packages fetchFromGitHub lib writeText
    libgpgerror libgcrypt libpcap ndpi;
  inherit (python39Packages) buildPythonApplication pytest pytest-runner;
  removeHardPaths = writeText "remove_harcoded_paths.patch" ''
    diff --git a/setup.py b/setup.py
    index 0404580..e8cac57 100644
    --- a/setup.py
    +++ b/setup.py
    @@ -37,14 +37,12 @@ def setup_engine_cc():
         if sys.platform == 'darwin':
             platform_compiler = "clang"
         print("\nSetting up engine_cc. Platform: {plat}, Byteorder: {bo}".format(plat=sys.platform, bo=sys.byteorder))
    -    subprocess.check_call([platform_compiler, '-I/usr/local/include/ndpi', '-shared', '-o',
    +    subprocess.check_call([platform_compiler, '-I${ndpi}/include/ndpi', '-shared', '-o',
                                'nfstream/engine/engine_cc.so',
                                '-g', '-fPIC', '-DPIC', '-O2', '-Wall', 'nfstream/engine/engine_cc.c',
                                # Required compiled static libs
    -                           '/usr/local/lib/libpcap.a',
    -                           '/usr/local/lib/libndpi.a',
    -                           '/usr/local/lib/libgcrypt.a',
    -                           '/usr/local/lib/libgpg-error.a'
    +                           '${libpcap}/lib/libpcap.a',
    +                           '${ndpi}/lib/libndpi.a'
  pname = "nfstream";
  version = "6.3.5";
    owner = "nfstream";
    repo = "nfstream";
    rev = "v6.3.5";
  buildInputs = [ libgpgerror libgcrypt libpcap ndpi pytest pytest-runner ];
  NIX_DEBUG = 1;
  patches = [ removeHardPaths ];
  meta = with lib; {
but then I hit into a wall… it seems that nfstream requires custom sources at least of libpcap and I don’t know what the best way to proceed is… I’m no really a C packaging expert…
I would make a patch upstream where people can specify alternate paths:
 +                           'os.env.get("NFSTREAM_LIB_PCAP", '/local/lib/libpcap.a'),
then in your derivation, you just need to do:
  NFSTREAM_LIB_PCAP = "${lib.getLib libpcap}/lib/libpcap.a";
It also appears that it wants the statically compiled versions of those libraries, so you will need to pull them from pkgsStatic package set.
I saw that libgpg-error and libgcrypt must be compiled statically. How can i specify that only those libs should be statically compiled ?
I’ll watch the video that u linked in the afternoon :smiley:
Uh that’s neat! At first I thought it would be easier :smiley: Probably my not familiarity with python doesn’t help me too much. And i’m also having trouble finding the resources to make my own patches…
Appreciate your help!
pkgsStatic.libgcrypt
[08:29:43] jon@nixos ~/projects/nixpkgs (master)
$ nix-build -A pkgsStatic.libgcrypt
/nix/store/nz97vkd5zpvps6kz38ancy9z51daa3fi-libgcrypt-static-x86_64-unknown-linux-musl-1.9.4
[08:29:52] jon@nixos ~/projects/nixpkgs (master)
$ tree ./result
./result
└── lib
    ├── libgcrypt.a
    └── libgcrypt.la
1 directory, 2 files
Basically adding in the diff {pkgsStatic.libcrypt} and {pkgsStatic.libgpgerror} would do the trick?
