Update: The issue was that some qt6 modules pull in python3, but that dependency isn’t overridden when using python311 because qt6 isn’t a Python package. Fixed it in this commit.
Cool, nice catch and thanks for looking into it again - I was on the right track but couldn’t figure it out. Can you shortly explain how you get on the right track?
Is there a reason you preferred a patch over the substituteInPlace even it should be relative temporary as the code got changed for pillow > 10.0.0 which seems not backwards compatible? Should we suggest this change upstream for this reason as well?
I knew the issue affected pyside6 but not every Python package. So, I started removing pieces of the pyside6 derivation until I narrowed down the issue to the optional qt6 modules. Then, I checked for any python references in those modules, and saw that they are pulling in python3 but that qt6 is not part of pythonPackages. So, I checked how this is handled for other packages, and replicated that pattern for qt6.
As for the patch, I prefer the patch because it will cause a build failure when the upstream is updated, signalling that the patch can be removed. We’ll see what reviewers think.
I changed the version to latest develop release requiring release requiring at least python3.11. But despite different try’s (but this one was the most promising/comprehensible I always end up with:
nix log /nix/store/7zx1ydskf5597973acs81ijzay9fgz74-streamdeck-ui-3.1.0-develop.2.drv
warning: The interpretation of store paths arguments ending in `.drv` recently changed. If this command is now failing try again with '/nix/store/7zx1ydskf5597973acs81ijzay9fgz74-streamdeck-ui-3.1.0-develop.2.drv^*'
Sourcing python-remove-tests-dir-hook
Sourcing python-catch-conflicts-hook.sh
Sourcing python-remove-bin-bytecode-hook.sh
Sourcing pip-build-hook
Using pipBuildPhase
Using pipShellHook
Sourcing pip-install-hook
Using pipInstallPhase
Sourcing python-imports-check-hook.sh
Using pythonImportsCheckPhase
Sourcing python-namespaces-hook
@nix { "action": "setPhase", "phase": "qtPreHook" }
qtPreHook
@nix { "action": "setPhase", "phase": "unpackPhase" }
unpacking sources
unpacking source archive /nix/store/hjic3ls7h9pwmlxxf8ncdismdgnb28zm-source
source root is source
setting SOURCE_DATE_EPOCH to timestamp 315619200 of file source/tests/test_stream_deck_monitor.py
@nix { "action": "setPhase", "phase": "patchPhase" }
patching sources
applying patch /nix/store/svlxvifkwni08pblaiaphiirxrw272zn-update-pillow.patch
patching file pyproject.toml
Hunk #1 succeeded at 14 with fuzz 2.
@nix { "action": "setPhase", "phase": "updateAutotoolsGnuConfigScriptsPhase" }
@nix { "action": "setPhase", "phase": "configurePhase" }
configuring
@nix { "action": "setPhase", "phase": "buildPhase" }
building
Executing pipBuildPhase
Creating a wheel...
/nix/store/9hwaihb8rhlvq8s7xq11m204jp51h6xi-python3-3.11.4/bin/python3.11: No module named pip
does this make sense for you or would you just wait until it’s a stable release and have a look then?
Should we maybe do the change of qt-python before as it triggers far more rebuilds?
