Hello, I’m new on the NixOS world, but I think it can be very useful for setting up data-science environments.
I wanted to create a default.nix file that could provide all devs the same environment, but I get always the error: “Torch not compiled with CUDA enabled”
After reading the tutorials and the docs, I came up with this:
{ sources ? import ./nix/sources.nix
, pkgs ? import sources.nixpkgs {}
pkgs.mkShell {
buildInputs = [
pkgs.python38
pkgs.cudaPackages.cudatoolkit_10
pkgs.python38Packages.pytorch
pkgs.python38Packages.unidecode
pkgs.python38Packages.inflect
pkgs.python38Packages.librosa
pkgs.python38Packages.pip
shellHook = ''
echo "You are now using a NIX environment"
export CUDA_PATH=${pkgs.cudatoolkit}
I’m using branch 20.9
"nixpkgs": {
"branch": "nixos-20.09",
"description": "Nix Packages collection",
"homepage": "",
"owner": "NixOS",
"repo": "nixpkgs",
"rev": "88f00e7e12d2669583fffd3f33aae01101464386",
"sha256": "0972lcah2wm1j7ab5acnpn1il68q90cdqhvq1vj4nlnygnwzhcfr",
"type": "tarball",
"url": "https://github.com/NixOS/nixpkgs/archive/88f00e7e12d2669583fffd3f33aae01101464386.tar.gz",
"url_template": "https://github.com/<owner>/<repo>/archive/<rev>.tar.gz"
But when I run:
nix-shell
python
>>> import torch
>>> torch.cuda.current_device()
File "<stdin>", line 1, in <module>
File "/nix/store/9l5ganwsbn8cir7skq1af8y1jf4przmx-python3.8-pytorch-1.6.0/lib/python3.8/site-packages/torch/cuda/__init__.py", line 384, in current_device
_lazy_init()
File "/nix/store/9l5ganwsbn8cir7skq1af8y1jf4przmx-python3.8-pytorch-1.6.0/lib/python3.8/site-packages/torch/cuda/__init__.py", line 186, in _lazy_init
_check_driver()
File "/nix/store/9l5ganwsbn8cir7skq1af8y1jf4przmx-python3.8-pytorch-1.6.0/lib/python3.8/site-packages/torch/cuda/__init__.py", line 61, in _check_driver
raise AssertionError("Torch not compiled with CUDA enabled")
AssertionError: Torch not compiled with CUDA enabled
How can I make this work?
Thanks!
