And I am running it with: nix-shell --run “jupyter lab”
When I do it fails with the following error:
error:
at /derivation-internal.nix:9:12:
8|
9| strict = derivationStrict drvAttrs;
10|
… while evaluating derivation 'nix-shell'
whose name attribute is located at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/stdenv/generic/make-derivation.nix:348:7
… while evaluating attribute 'buildInputs' of derivation 'nix-shell'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/stdenv/generic/make-derivation.nix:395:7:
394| depsHostHost = elemAt (elemAt dependencies 1) 0;
395| buildInputs = elemAt (elemAt dependencies 1) 1;
396| depsTargetTarget = elemAt (elemAt dependencies 2) 0;
error: qiskit-terra-0.25.1 not supported for interpreter python3.11
To me, the key failure seems to be related to Qiskit-Terra due to
When I check the status of Qiskit-Terra it appears to be compatible.
You can reproduce this by evaluating just python311Packages.qiskit-terra, which is currently marked as disabled for Python 3.11 pending an update. You might have success using python310 instead.
I updated my script to the following but still get an error. I am terribly new at this and am probably misinterpreting the documentation.
{ pkgs ? import (fetchTarball "https://github.com/NixOS/nixpkgs/archive/nixos-unstable.tar.gz") {} }:
my-python-packages = python-packages: with python-packages; [
matplotlib
numpy
pandas
scipy
qiskit
python-with-my-packages = pkgs.python310.withPackages my-python-packages;
pkgs.mkShell {
buildInputs = [
shellHook = ''
# Set NIXPKGS_ALLOW_BROKEN to 1
export NIXPKGS_ALLOW_BROKEN=1
echo "NIXPKGS_ALLOW_BROKEN is set to $NIXPKGS_ALLOW_BROKEN"
The error produuced is
error:
8|
10|
error: Package ‘python3.10-qiskit-aer-0.12.2’ in /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/python-modules/qiskit-aer/default.nix:151 is marked as broken, refusing to evaluate.
a) To temporarily allow broken packages, you can use an environment variable
for a single invocation of the nix tools.
$ export NIXPKGS_ALLOW_BROKEN=1
Note: When using `nix shell`, `nix build`, `nix develop`, etc with a flake,
then pass `--impure` in order to allow use of environment variables.
b) For `nixos-rebuild` you can set
{ nixpkgs.config.allowBroken = true; }
in configuration.nix to override this.
c) For `nix-env`, `nix-build`, `nix-shell` or any other Nix command you can add
{ allowBroken = true; }
to ~/.config/nixpkgs/config.nix.
error:
8|
10|
… while evaluating derivation 'python3-3.10.13-env'
… while evaluating attribute 'passAsFile' of derivation 'python3-3.10.13-env'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/build-support/trivial-builders/default.nix:88:7:
87| inherit buildCommand name;
88| passAsFile = [ "buildCommand" ]
89| ++ (derivationArgs.passAsFile or []);
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/interpreters/python/wrapper.nix:20:13:
19| env = let
20| paths = requiredPythonModules (extraLibs ++ [ python ] ) ;
21| pythonPath = "${placeholder "out"}/${python.sitePackages}";
… while calling 'requiredPythonModules'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/interpreters/python/python-packages-base.nix:57:27:
56| # Get list of required Python modules given a list of derivations.
57| requiredPythonModules = drvs: let
58| modules = lib.filter hasPythonModule drvs;
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/interpreters/python/python-packages-base.nix:59:6:
59| in lib.unique ([python] ++ modules ++ lib.concatLists (lib.catAttrs "requiredPythonModules" modules));
60|
… while calling 'foldl''
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/lists.nix:139:5:
138| # The list to fold
139| list:
140|
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/interpreters/python/python-packages-base.nix:74:33:
73| pythonPath = [ ]; # Deprecated, for compatibility.
74| requiredPythonModules = requiredPythonModules drv.propagatedBuildInputs;
75| };
… from call site
60|
139| list:
140|
… from call site
75| };
… from call site
60|
139| list:
140|
… while calling anonymous lambda
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/lists.nix:864:25:
863| */
864| unique = foldl' (acc: e: if elem e acc then acc else acc ++ [ e ]) [];
865|
… while evaluating derivation 'python3.10-torch-2.1.1'
… while evaluating attribute 'USE_NCCL' of derivation 'python3.10-torch-2.1.1'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/python-modules/torch/default.nix:276:3:
275|
276| USE_NCCL = setBool (cudaPackages ? nccl);
277| USE_SYSTEM_NCCL = setBool useSystemNccl; # don't build pytorch's third_party NCCL
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/python-modules/torch/default.nix:276:14:
275|
… while calling 'setBool'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/python-modules/torch/default.nix:61:13:
60|
61| setBool = v: if v then "1" else "0";
62|
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/top-level/all-packages.nix:7329:21:
7328| cudaPackages_11_8 = callPackage ./cuda-packages.nix { cudaVersion = "11.8"; };
7329| cudaPackages_11 = recurseIntoAttrs cudaPackages_11_8;
7330|
… while calling 'recurseIntoAttrs'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/attrsets.nix:1145:5:
1144| # An attribute set to scan for derivations.
1145| attrs:
1146| attrs // { recurseForDerivations = true; };
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/top-level/all-packages.nix:7328:23:
7327| cudaPackages_11_7 = callPackage ./cuda-packages.nix { cudaVersion = "11.7"; };
… while calling 'callPackageWith'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/customisation.nix:153:35:
152| */
153| callPackageWith = autoArgs: fn: args:
154| let
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/trivial.nix:440:7:
439| { # TODO: Should we add call-time "type" checking like built in?
440| __functor = self: f;
441| __functionArgs = args;
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/customisation.nix:96:17:
95| in
96| mirrorArgs (origArgs:
97| let
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/customisation.nix:98:16:
97| let
98| result = f origArgs;
99|
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/top-level/cuda-packages.nix:23:1:
22| # I've (@connorbaker) attempted to do that, though I'm unsure of how this will interact with overrides.
23| {
24| callPackage,
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/top-level/cuda-packages.nix:117:18:
116|
117| cudaPackages = customisation.makeScope newScope (
118| fixedPoints.extends composedExtension passthruFunction
… while calling 'makeScope'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/customisation.nix:317:25:
316| */
317| makeScope = newScope: f:
318| let self = f self // {
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/customisation.nix:318:16:
319| newScope = scope: newScope (self // scope);
… while calling 'extends'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/fixed-points.nix:141:24:
140| */
141| extends = f: rattrs: self: let super = rattrs self; in super // f self super;
142|
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/fixed-points.nix:141:67:
140| */
142|
… while calling 'composeExtensions'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/fixed-points.nix:149:18:
148| composeExtensions =
149| f: g: final: prev:
150| let fApplied = f final prev;
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/fixed-points.nix:152:22:
151| prev' = prev // fApplied;
152| in fApplied // g final prev';
153|
… from call site
153|
… from call site
153|
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/fixed-points.nix:150:22:
… while calling 'extension'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/cuda-modules/generic-builders/multiplex.nix:104:12:
103| extension =
104| final: _:
105| let
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/cuda-modules/generic-builders/multiplex.nix:86:36:
85| # newestToOldestSupportedPackage :: List (AttrSet Packages)
86| newestToOldestSupportedPackage = lists.reverseList supportedPackages;
87|
… while calling 'reverseList'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/lists.nix:510:17:
509| */
510| reverseList = xs:
511| let l = length xs; in genList (n: elemAt xs (l - n - 1)) l;
… from call site
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/cuda-modules/generic-builders/multiplex.nix:79:16:
78| # Get all of the packages for our given platform.
79| redistArch = flags.getRedistArch hostPlatform.system;
80|
… while calling 'getRedistArch'
at /nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/pkgs/development/cuda-modules/flags.nix:136:5:
135| getRedistArch =
136| nixSystem:
137| if nixSystem == "aarch64-linux" then
error: Unsupported Nix system: aarch64-darwin
It looks like the Qiskit packages are unmaintained; the last time anyone worked on them was in April 2022 and without updates they eventually became incompatible with the rest of nixpkgs.
