Quickgui with bridged networking, failed to create tun device
I’ve been using quickgui for a bit and it’s quite handy. Recently, I tried to allow one of the VMs to access the LAN through a bridge. Now the VM won’t start. Giving me this error:
failed to create tun device: Operation not permitted
qemu-system-x86_64: -nic bridge,br=br0,model=virtio-net-pci: bridge helper failed
Pertinent part of my configuration.nix file:
  networking = {
    hostName = "oak";
    networkmanager.enable = true;
    wireless.enable = true;
    firewall = rec {
      trustedInterfaces = [ "br0" ];
      allowedTCPPorts = [
        3128 # SPICE
        # 3131 # deskreen
      allowedTCPPortRanges = [
          # Allow KDEconnect to work:
          from = 1714;
          to = 1764;
      allowedUDPPortRanges = allowedTCPPortRanges;
    bridges = {
      br0 = {
        interfaces = [ "enp4s0" ];
    interfaces.br0.ipv4 = {
      addresses = [
          address = "192.168.1.111";
          prefixLength = 24;
      routes = [
          address = "192.168.1.0";
          prefixLength = 24;
          via = "192.168.1.1";
  virtualisation = {
    libvirtd = {
      allowedBridges = [
        "virbr0"
        "br0"
      qemu.vhostUserPackages = with pkgs; [ virtiofsd ];
    spiceUSBRedirection.enable = true;
  programs.virt-manager.enable = true;
Bridge is up and working as expected (I think):
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp4s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel master br0 state UP group default qlen 1000
link/ether 74:56:3c:49:65:51 brd ff:ff:ff:ff:ff:ff
altname enx74563c496551
3: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.1.111/24 scope global br0
inet6 fe80::7656:3cff:fe49:6551/64 scope link proto kernel_ll
4: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 80:af:ca:eb:99:c7 brd ff:ff:ff:ff:ff:ff
altname wlp0s20f0u11u3u1u4u3u1
altname wlx80afcaeb99c7
inet 192.168.1.232/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
valid_lft 84835sec preferred_lft 84835sec
inet6 fe80::74af:d1f:ab12:d4a2/64 scope link noprefixroute
Complete error from running quickemu manually:
quickemu --vm proxmox-ve-9.1-1.conf
proxmox-ve-9.1-1.conf: line 9: tap: command not found
Quickemu 4.9.9 using /nix/store/bi3pasa54bi5sarwa5pj8qbiv7vbksdf-qemu-10.2.1/bin/qemu-system-x86_64 v10.2.1
- Host:     NixOS 26.05 (Yarara) running Linux 6.18.15 oak
- CPU:      Intel(R) Core(TM) i9-14900K
- CPU VM:   host, 1 Socket(s), 8 Core(s), 2 Thread(s)
- RAM VM:   4G RAM
- BOOT:     EFI (Linux), OVMF (/nix/store/bi3pasa54bi5sarwa5pj8qbiv7vbksdf-qemu-10.2.1/share/qemu/edk2-x86_64-code.fd), EFI Vars (proxmox-ve-9.1-1/OVMF_VARS.fd), SecureBoot (off).
- Disk:     proxmox-ve-9.1-1/disk.qcow2 (20G)
- Display:  GTK, virtio-vga-gl, GL (on), VirGL (on) @ (1280 x 800)
- Sound:    intel-hda (hda-micro)
- ssh:      On host:  ssh user@localhost -p 22220
- WebDAV:   On guest: dav://localhost:9843/
- 9P:       On guest: sudo mount -t 9p -o trans=virtio,version=9p2000.L,msize=104857600 Public-sergio ~/Public
- smbd:     On guest: smb://10.0.2.4/qemu
- Network:  Bridged (br0)
- Monitor:  On host:  socat -,echo=0,icanon=0 unix-connect:proxmox-ve-9.1-1/proxmox-ve-9.1-1-monitor.socket
- Serial:   On host:  socat -,echo=0,icanon=0 unix-connect:proxmox-ve-9.1-1/proxmox-ve-9.1-1-serial.socket
- Process:  ERROR! Failed to start proxmox-ve-9.1-1.conf as proxmox-ve-9.1-1
Contents of proxmox-ve-9.1-1.conf:
#!/nix/store/62p3pgibss3kp7awxxjjcxrhnrmmdala-quickemu-4.9.7-unstable-2025-12-28/bin/quickemu --vm
guest_os="linux"
disk_img="proxmox-ve-9.1-1/disk.qcow2"
iso="proxmox-ve-9.1-1/proxmox-ve_9.1-1.iso"
disk_size="20G"
ram="4G"
network="br0"
Anybody manage to get this working?
Ran into the same issue with roughly the same config. This seems to be an issue with the bridge helper wrapper not having the right permissions.
Instead of using the helper directly, try setting network=”none" and then passing in the bridge name manually as shown here:
quickemu --vm YOUR_CONF_FILE.conf --display spice --extra_args “-nicbridge,br=YOUR_BRIDGE_NAME,model=virtio-net-pci,helper=/run/wrappers/bin/qemu-bridge-helper”
This works for me. Though honestly I’m not sure why, given that it’s still using the same wrapper in the end…?
Edit: alternatively, just run it under sudo -E to maintain env vars that would otherwise break spice. (This is probably just how we should be doing :melting_face: ).
A more long term overlay/patch seems to be discussed in this issue: Qemu fails to start when told to use bridged networking. · Issue #311807 · NixOS/nixpkgs · GitHub
I’m not experienced with Nix and unfortunately I don’t have the time to dig into that :frowning:
Never used quickgui so I can’t speak for that.
