Radicale is a self-hosted calendar and contact solution that is “lightweight solution, easy to use, easy to install, easy to configure.”
I can finally dump my NextCloud, which was a sprawling mess of PHP scripts. Managing a NextCloud instance over a long period of a time requires the sysadmin to be mindful of the stateful configuration, which can only be upgraded one major version at a time.
I stumbled over Radicale a couple years ago right after I had spent an entire day writing a playbook to build a dockerless NextCloud container. I should have switched immediately, I’ve wasted numerous hours over that period making sure my container was up to date, or needlessly fiddling with settings just to feel like I had a handle on how the thing was going to operate.
Running radicale on NixOS:
service.radicale = {
settings = {
server = {
hosts = [ "127.0.0.1:5232" "[::]:5232" ];
auth = {
type = "htpasswd";
htpasswd_filename = "/etc/radicale/users";
htpasswd_encryption = "bcrypt";
storage = {
filesystem_folder = "/var/lib/radicale/collections";
Nginx configuration snippet from:
locations."/radicale/" = {
proxyPass = "http://127.0.0.1:5232/";
extraConfig = ''
proxy_set_header X-Script-Name /radicale;
proxy_pass_header Authorization;
Creating my account after nixos-rebuild switch:
nix-shell -p apacheHttpd --run "htpasswd -B -c /etc/radicale/users bleetube"
The web interface is dead simple and let’s you create, import, or export calendars or addressbooks. I exported the vcf addressbook and ics calendar from my NextCloud instance and imported them into Radicale. The UI gives you URIs for the calendar or contacts, and I pasted that in along with my username in the relevant add dialog in Thunderbird.
Likewise, I added the account in davx5 on Android using the first “Login with URL and user name” option. For the URL this time, I appended my username, so it was https://example.com/radicale/myusername and davx was able to sync both the calendar and the contacts from that endpoint.
