Hi guys
I’m trying to set up a raspberry PI with NixOS using the official firmware and bootloader.
Most of the wiki examples and code out there uses u-boot, which I specifically do not want to use, because then I can use the official device trees and hardware support should be better.
I already got it working to a point where it boots and it works using the official touch screen display, which didn’t work in my older attempts using u-boot.
But it doesn’t reliably boot to the login prompt, and logging in using SSH takes about 2 minutes, so something still not good, and I can’t figure out the cause.
Here’s the configuration I currently have:
{config,pkgs,lib,...}:{
boot.loader.raspberryPi = {
version = 3;
firmwareConfig = ''
gpu_mem=256
dispmanx_offline=1
display_rotate=1
i18n.defaultLocale = "de_CH.UTF-8";
console = {
font = "Lat2-Terminus16";
keyMap = "de_CH-latin1";
boot.kernelPackages = pkgs.linuxPackages_rpi3;
hardware.enableRedistributableFirmware = true;
boot.kernelModules = lib.mkForce [ "vc4" "i2c_bcm2835" ];
boot.initrd.availableKernelModules = lib.mkForce [ ];
boot.kernelParams = [ "root=/dev/mmcblk0p2" "rw" "rootwait" "smsc95xx.turbo_mode=N" ];
boot.initrd.supportedFilesystems = lib.mkForce ["ext4" "fat32"];
boot.supportedFilesystems = lib.mkForce ["ext4" "fat32"];
services.openssh.permitRootLogin = "yes";
networking.firewall.enable = false;
networking.hostName = "display";
users.users.root.openssh.authorizedKeys.keys = [
"ssh-rsa AAAAB3NzaC1yc2EAAAABIwAAAQEA289vddtq4A1/TNluSFhWE9VZY5CXXa/458iSUzeXtfC5mN/+dZe8kzCQmqBIqhYETdhMi/dvJyzL7oADJUFKL1cxLjF4A+MoBbRD1lsk9a0Fk08SsGGeJkW3Xb/B/NJbHGEYIB58ALS8kWJgFP0YH6gvZGXn8Fv2Odkorj65H702TOrKCib/CfWrwXd21cDPrXihFgKifsPKtk1odnobJS1h1ADOoIZqRpOKyQBr6+H352BuWhQpARmlII5soKpVxbTANrBvLEl6dhFzRf6dw2ftgdwRfJYjFlyxFArp4MweQ+9bi+D5YjeBi6uwGsRZfemdelXS3u/oxi4SDCJkLw=="
nix.extraOptions = ''
keep-outputs = true
keep-derivations = true
experimental-features = nix-command flakes
boot.loader.grub.enable = false;
sdImage = {
populateFirmwareCommands = "${config.system.build.installBootLoader} ${config.system.build.toplevel} -d $NIX_BUILD_TOP/firmware/";
populateRootCommands = ''
mkdir -p ./files/nix/var/nix/profiles/
ln -s ${config.system.build.toplevel} ./files/nix/var/nix/profiles/system
firmwareSize = 512;
compressImage = false;
# to mount: https://thomasheinz.net/img-file-disk-image-unter-linux-mounten/
system.stateVersion = "23.05"; # Did you read the comment?
And the flake.nix
description = "A very basic flake";
outputs = { self, nixpkgs }: rec {
nixosConfigurations.default = nixpkgs.lib.nixosSystem {
system = "aarch64-linux";
modules = [
"${nixpkgs}/nixos/modules/profiles/base.nix"
"${nixpkgs}/nixos/modules/installer/sd-card/sd-image.nix"
./configuration.nix
specialArgs = { inherit nixpkgs; };
images.default = nixosConfigurations.default.config.system.build.sdImage;
and lock file
"nodes": {
"nixpkgs": {
"locked": {
"lastModified": 1669320964,
"narHash": "sha256-EBFw+ge12Pcr3qCk8If3/eMBAoQLR7ytndXZoRevUtM=",
"path": "/nix/store/dd636dqmf0s78wnv83rssk6qbj6jan1f-source",
"rev": "27ccd29078f974ddbdd7edc8e38c8c8ae003c877",
"type": "path"
"original": {
"id": "nixpkgs",
"type": "indirect"
"root": {
"inputs": {
"nixpkgs": "nixpkgs"
"root": "root",
"version": 7
Pinging the PI works flawlessly, and I tried running a simple web server on it and it responded quickly, so there don’t seem to be network issues. I just can’t figure out what the issue with SSH is…
Does someone have any advice?
My end goal is to turn the PI into a kiosk system, displaying a web page.
If I can’t get it to work I also thought about using the official minimal raspbian image, and then installing the whole graphical stack onto it using nix, but that would be worst case…
The log of a login attempt looks like this:
Jan 08 23:10:32 display systemd[1]: Reached target User and Group Name Lookups.
Jan 08 23:10:32 display systemd[1]: Reached target Host and Network Name Lookups.
Jan 08 23:10:32 display systemd[1]: Reached target Multi-User System.
Jan 08 23:10:32 display systemd[1]: Started Name Service Cache Daemon.
Jan 08 23:10:32 display nscd[1077]: 1077 monitoring directory `/etc` (2)
Jan 08 23:10:32 display nscd[1077]: 1077 monitoring file `/etc/nsswitch.conf` (8)
Jan 08 23:10:32 display nscd[1077]: 1077 monitoring file `/etc/netgroup` (7)
Jan 08 23:10:32 display nscd[1077]: 1077 monitoring file `/etc/services` (6)
Jan 08 23:10:32 display nscd[1077]: 1077 monitoring file `/etc/resolv.conf` (5)
Jan 08 23:10:32 display nscd[1077]: 1077 monitoring file `/etc/hosts` (4)
Jan 08 23:10:32 display nscd[1077]: 1077 monitoring file `/etc/group` (3)
Jan 08 23:10:32 display nscd[1077]: 1077 monitoring file `/etc/passwd` (1)
Jan 08 23:10:32 display systemd[1]: Starting Name Service Cache Daemon...
Jan 08 23:10:32 display systemd[1]: Stopped Name Service Cache Daemon.
Jan 08 23:10:32 display systemd[1]: nscd.service: Failed with result 'timeout'.
Jan 08 23:10:32 display systemd[1]: nscd.service: Processes still around after final SIGKILL. Entering failed mode.
Jan 08 23:10:18 display sshd[1021]: pam_systemd(sshd:session): Failed to create session: Connection timed out
Jan 08 23:09:23 display systemd[1]: user@0.service: Killing process 937 (systemd) with signal SIGKILL.
Jan 08 23:09:23 display systemd[1]: user@0.service: State 'stop-sigterm' timed out. Killing.
Jan 08 23:09:01 display systemd[1]: nscd.service: Killing process 651 (nscd) with signal SIGKILL.
Jan 08 23:09:01 display systemd[1]: nscd.service: Killing process 647 (nscd) with signal SIGKILL.
Jan 08 23:09:01 display systemd[1]: nscd.service: State 'final-sigterm' timed out. Killing.
Jan 08 23:08:18 display systemd-logind[587]: New session 3 of user root.
Jan 08 23:08:18 display sshd[1021]: pam_unix(sshd:session): session opened for user root(uid=0) by (uid=0)
Jan 08 23:08:18 display sshd[1021]: Accepted publickey for root from 192.168.1.60 port 34694 ssh2: RSA SHA256:X82AQ1Qim54HWi1k30G5E6G6Bgy8pzFUZ9O/rMgUJNE
