I am new to Nixos and I am not able to get any audio from my Acer laptop. Digging a little deeper it seems that while the audio card comes up in hardware info, it seems to not be recognized by some of the audio driver packages. I’ve tried alsa, pipewire, pulseaudio.
Is there some configuration I need to do in order for pipewire to work? Or possibly some special firmware?
Thank you for your time!
Nix Configuration:
# Enable sound with pipewire.
sound.enable = true;
security.rtkit.enable = true;
services.pipewire = {
alsa.enable = true;
alsa.support32Bit = true;
pulse.enable = true;
jack.enable = true;
#media-session.enable = true;
alsa-firmware
alsa-oss
alsa-lib
alsa-utils
alsa-tools
alsaequal
pipewire
jack2
pulseaudio
carla
Pipewire:
$ systemctl status pipewire
○ pipewire.service
Loaded: masked (Reason: Unit pipewire.service is masked.)
Active: inactive (dead)
$ systemctl status --user pipewire
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/etc/systemd/user/pipewire.service; linked-runtime; preset: enabled)
Drop-In: /nix/store/mgf7p01zgbih3pc50zaaaw00bxy05l98-user-units/pipewire.service.d
└─overrides.conf
Active: active (running) since Fri 2023-12-08 23:01:24 CST; 1h 7min ago
TriggeredBy: ● pipewire.socket
Main PID: 1369 (pipewire)
Tasks: 7 (limit: 9379)
Memory: 9.3M
CPU: 151ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─1369 /nix/store/n5azqf4qgng00pzdw0xzg7dqjfvsfcgs-pipewire-0.3.85/bin/pipewire
Dec 08 23:01:24 nyxos systemd[1100]: Started PipeWire Multimedia Service.
Dec 08 23:01:25 nyxos pipewire[1369]: [0:00:17.398845024] [1369] INFO IPAManager ipa_manager.cpp:143 libcamera is n>
Dec 08 23:01:25 nyxos pipewire[1369]: [0:00:17.399051449] [1369] INFO Camera camera_manager.cpp:298 libcamera v0.0.5
Dec 08 23:03:40 nyxos pipewire[1369]: spa.audioadapter: 0x5638de5e09f8: scheduling stopped node
Other system info:
$ dmesg | grep -i audio
[ 5.634957] snd_soc_skl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 5.707323] HDMI HDA Codec ehdaudio0D2: Max dais supported: 3
$ lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 08)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #1 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Multimedia audio controller: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
02:00.0 Network controller: Intel Corporation Wireless 7265 (rev 59)
$ nix-shell -p hwinfo --run "hwinfo --sound"
15: PCI 1f.3: 0401 Multimedia audio controller
[Created at pci.386]
Unique ID: nS1_.6x3hYXY2gHF
SysFS ID: /devices/pci0000:00/0000:00:1f.3
SysFS BusID: 0000:00:1f.3
Hardware Class: sound
Model: "Intel Sunrise Point-LP HD Audio"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x9d71 "Sunrise Point-LP HD Audio"
SubVendor: pci 0x1025 "Acer Incorporated [ALI]"
SubDevice: pci 0x1269
Revision: 0x21
Driver: "snd_soc_skl"
Driver Modules: "snd_soc_skl"
Memory Range: 0xb1128000-0xb112bfff (rw,non-prefetchable)
Memory Range: 0xb1100000-0xb110ffff (rw,non-prefetchable)
IRQ: 16 (60 events)
Module Alias: "pci:v00008086d00009D71sv00001025sd00001269bc04sc01i00"
Config Status: cfg=new, avail=yes, need=no, active=unknown
$ wpctl status
Audio
├─ Devices:
├─ Sinks:
│ * 50. Dummy Output [vol: 1.00]
├─ Sink endpoints:
├─ Sources:
├─ Source endpoints:
└─ Streams:
$ lsmod
Module Size Used by
cmac 16384 1
ccm 20480 3
qrtr 49152 4
snd_seq_dummy 16384 0
snd_hrtimer 16384 1
snd_seq 90112 7 snd_seq_dummy
snd_seq_device 16384 1 snd_seq
af_packet 57344 6
snd_soc_skl_hda_dsp 24576 0
snd_soc_intel_hda_dsp_common 20480 1 snd_soc_skl_hda_dsp
snd_soc_hdac_hdmi 45056 1 snd_soc_skl_hda_dsp
snd_soc_skl_ssp_clk 16384 0
snd_sof_pci_intel_skl 16384 0
snd_sof_intel_hda_common 188416 1 snd_sof_pci_intel_skl
snd_soc_hdac_hda 24576 1 snd_sof_intel_hda_common
soundwire_intel 49152 1 snd_sof_intel_hda_common
soundwire_generic_allocation 16384 1 soundwire_intel
soundwire_cadence 36864 1 soundwire_intel
snd_sof_intel_hda 20480 1 snd_sof_intel_hda_common
snd_sof_pci 24576 2 snd_sof_intel_hda_common,snd_sof_pci_intel_skl
snd_sof_xtensa_dsp 16384 1 snd_sof_intel_hda_common
snd_sof 270336 2 snd_sof_pci,snd_sof_intel_hda_common
snd_sof_utils 20480 1 snd_sof
soundwire_bus 98304 3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence
iwlmvm 442368 0
snd_soc_avs 143360 0
snd_soc_hda_codec 24576 1 snd_soc_avs
snd_soc_dmic 16384 0
mac80211 1093632 1 iwlmvm
snd_soc_skl 180224 1 snd_soc_skl_ssp_clk
i915 3047424 45
snd_soc_sst_ipc 20480 1 snd_soc_skl
snd_soc_sst_dsp 40960 1 snd_soc_skl
snd_hda_ext_core 36864 6 snd_soc_avs,snd_soc_hda_codec,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_soc_skl
snd_soc_acpi_intel_match 77824 3 snd_sof_intel_hda_common,snd_soc_skl,snd_sof_pci_intel_skl
snd_soc_acpi 16384 3 snd_soc_acpi_intel_match,snd_sof_intel_hda_common,snd_soc_skl
snd_soc_core 352256 10 snd_soc_avs,snd_soc_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_soc_skl,snd_soc_dmic,snd_soc_skl_hda_dsp
libarc4 16384 1 mac80211
intel_tcc_cooling 16384 0
snd_compress 28672 1 snd_soc_core
x86_pkg_temp_thermal 20480 0
intel_powerclamp 20480 0
ac97_bus 16384 1 snd_soc_core
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_hda_intel 57344 0
snd_intel_dspcfg 32768 5 snd_soc_avs,snd_hda_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_skl
uvcvideo 131072 4
snd_intel_sdw_acpi 20480 2 snd_sof_intel_hda_common,snd_intel_dspcfg
coretemp 20480 0
snd_hda_codec 176128 8 snd_soc_avs,snd_soc_hda_codec,snd_hda_intel,snd_soc_intel_hda_dsp_common,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda,snd_soc_skl_hda_dsp
crc32_pclmul 16384 0
polyval_clmulni 16384 0
polyval_generic 16384 1 polyval_clmulni
videobuf2_vmalloc 20480 1 uvcvideo
nls_iso8859_1 16384 1
gf128mul 16384 1 polyval_generic
videobuf2_memops 20480 1 videobuf2_vmalloc
ghash_clmulni_intel 16384 0
nls_cp437 20480 1
videobuf2_v4l2 36864 1 uvcvideo
sha512_ssse3 49152 0
sha512_generic 16384 1 sha512_ssse3
sha256_ssse3 36864 0
snd_hda_core 118784 11 snd_soc_avs,snd_soc_hda_codec,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_intel_hda_dsp_common,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda
vfat 24576 1
videobuf2_common 65536 4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
sha1_ssse3 32768 0
fat 90112 1 vfat
iwlwifi 462848 1 iwlmvm
snd_hwdep 16384 1 snd_hda_codec
btusb 69632 0
aesni_intel 393216 3
hid_multitouch 32768 0
videodev 282624 5 videobuf2_v4l2,uvcvideo,videobuf2_common
btrtl 28672 1 btusb
crypto_simd 16384 1 aesni_intel
iTCO_wdt 16384 0
cryptd 24576 2 crypto_simd,ghash_clmulni_intel
btbcm 24576 1 btusb
snd_pcm 155648 13 snd_soc_avs,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_compress,snd_soc_core,snd_sof_utils,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
intel_pmc_bxt 16384 1 iTCO_wdt
rapl 16384 0
btintel 45056 1 btusb
watchdog 32768 1 iTCO_wdt
btmtk 16384 1 btusb
drm_buddy 20480 1 i915
intel_cstate 20480 0
mei_hdcp 24576 0
mei_pxp 20480 0
intel_rapl_msr 20480 0
acer_wmi 28672 0
intel_wmi_thunderbolt 20480 0
wmi_bmof 16384 0
sparse_keymap 16384 1 acer_wmi
cfg80211 1130496 3 iwlmvm,iwlwifi,mac80211
mc 73728 6 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
i2c_i801 36864 0
intel_uncore 217088 0
snd_timer 49152 3 snd_seq,snd_hrtimer,snd_pcm
bluetooth 913408 6 btrtl,btmtk,btintel,btbcm,btusb
snd 118784 13 snd_seq,snd_seq_device,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_sof,snd_timer,snd_soc_hdac_hdmi,snd_compress,snd_soc_core,snd_pcm
ttm 90112 1 i915
i2c_smbus 20480 1 i2c_i801
drm_display_helper 172032 1 i915
soundcore 16384 1 snd
ip6_tables 36864 2
cec 61440 1 i915
xt_conntrack 16384 2
ecdh_generic 16384 1 bluetooth
drm_kms_helper 192512 2 drm_display_helper,i915
rfkill 28672 8 acer_wmi,iwlmvm,bluetooth,cfg80211
intel_lpss_pci 28672 0
processor_thermal_device_pci_legacy 16384 0
ecc 40960 1 ecdh_generic
intel_lpss 16384 1 intel_lpss_pci
mei_me 53248 2
processor_thermal_device 20480 1 processor_thermal_device_pci_legacy
intel_gtt 24576 1 i915
libaes 16384 2 bluetooth,aesni_intel
nf_conntrack 172032 1 xt_conntrack
processor_thermal_rfim 16384 1 processor_thermal_device
mei 159744 5 mei_hdcp,mei_pxp,mei_me
agpgart 45056 2 intel_gtt,ttm
processor_thermal_mbox 16384 2 processor_thermal_rfim,processor_thermal_device
idma64 20480 0
i2c_algo_bit 16384 1 i915
virt_dma 20480 1 idma64
processor_thermal_rapl 20480 1 processor_thermal_device
fb_sys_fops 16384 1 drm_kms_helper
nf_defrag_ipv6 24576 1 nf_conntrack
syscopyarea 16384 1 drm_kms_helper
intel_pch_thermal 20480 0
video 65536 2 acer_wmi,i915
nf_defrag_ipv4 16384 1 nf_conntrack
intel_rapl_common 28672 2 intel_rapl_msr,processor_thermal_rapl
sysfillrect 16384 1 drm_kms_helper
i2c_hid_acpi 16384 0
sysimgblt 16384 1 drm_kms_helper
intel_soc_dts_iosf 20480 1 processor_thermal_device_pci_legacy
intel_xhci_usb_role_switch 16384 0
roles 16384 1 intel_xhci_usb_role_switch
thermal 28672 0
i2c_hid 32768 1 i2c_hid_acpi
tpm_crb 24576 0
int3403_thermal 20480 0
tpm_tis 16384 0
mousedev 24576 0
battery 28672 0
int340x_thermal_zone 20480 2 int3403_thermal,processor_thermal_device
ac 20480 0
wmi 36864 4 video,intel_wmi_thunderbolt,acer_wmi,wmi_bmof
pinctrl_sunrisepoint 28672 0
ip6t_rpfilter 16384 1
tiny_power_button 16384 0
int3400_thermal 20480 0
joydev 28672 0
tpm_tis_core 32768 1 tpm_tis
intel_pmc_core 53248 0
ipt_rpfilter 16384 1
acer_wireless 20480 0
acpi_thermal_rel 16384 1 int3400_thermal
acpi_pad 28672 0
button 24576 0
evdev 28672 24
input_leds 16384 0
led_class 20480 3 input_leds,acer_wmi,iwlmvm
mac_hid 16384 0
xt_pkttype 16384 2
serio_raw 20480 0
xt_LOG 20480 2
nf_log_syslog 20480 2
xt_tcpudp 20480 0
nft_compat 20480 11
nf_tables 299008 101 nft_compat
libcrc32c 16384 2 nf_conntrack,nf_tables
nfnetlink 20480 2 nft_compat,nf_tables
sch_fq_codel 20480 1
ctr 16384 1
loop 32768 0
tun 61440 0
tap 28672 0
macvlan 28672 0
bridge 311296 0
stp 16384 1 bridge
llc 16384 2 bridge,stp
kvm_intel 380928 0
kvm 1118208 1 kvm_intel
drm 581632 21 drm_kms_helper,drm_display_helper,drm_buddy,i915,ttm
irqbypass 16384 1 kvm
fuse 155648 3
deflate 16384 1
backlight 24576 5 video,acer_wmi,drm_display_helper,i915,drm
efi_pstore 16384 0
configfs 57344 1
efivarfs 24576 1
tpm 94208 3 tpm_tis,tpm_crb,tpm_tis_core
rng_core 20480 1 tpm
dmi_sysfs 20480 0
ip_tables 36864 1
x_tables 53248 9 xt_conntrack,ip6t_rpfilter,nft_compat,xt_LOG,xt_tcpudp,ip6_tables,ipt_rpfilter,xt_pkttype,ip_tables
autofs4 53248 0
ext4 958464 1
crc32c_generic 16384 0
crc16 16384 2 bluetooth,ext4
mbcache 16384 1 ext4
jbd2 163840 1 ext4
uas 32768 3
usb_storage 81920 1 uas
hid_generic 16384 0
usbhid 65536 0
hid 151552 4 i2c_hid,usbhid,hid_multitouch,hid_generic
sd_mod 57344 4
t10_pi 16384 1 sd_mod
crc64_rocksoft 20480 1 t10_pi
crc64 20480 1 crc64_rocksoft
crc_t10dif 20480 1 t10_pi
crct10dif_generic 16384 0
xhci_pci 24576 0
ahci 49152 0
xhci_pci_renesas 20480 1 xhci_pci
firmware_class 49152 15 btrtl,snd_soc_avs,snd_hda_intel,xhci_pci_renesas,btmtk,snd_sof,drm_display_helper,btintel,btbcm,iwlwifi,btusb,snd_soc_skl,i915,cfg80211,drm
libahci 49152 1 ahci
xhci_hcd 315392 1 xhci_pci
libata 389120 2 libahci,ahci
atkbd 36864 0
usbcore 339968 7 xhci_hcd,usbhid,usb_storage,uvcvideo,btusb,xhci_pci,uas
libps2 20480 1 atkbd
vivaldi_fmap 16384 1 atkbd
scsi_mod 274432 4 sd_mod,usb_storage,uas,libata
crct10dif_pclmul 16384 1
crct10dif_common 16384 3 crct10dif_generic,crc_t10dif,crct10dif_pclmul
crc32c_intel 24576 3
usb_common 16384 3 xhci_hcd,usbcore,uvcvideo
scsi_common 16384 4 scsi_mod,usb_storage,uas,libata
i8042 40960 1 acer_wmi
rtc_cmos 28672 1
serio 28672 4 serio_raw,atkbd,i8042
dm_mod 155648 0
dax 45056 1 dm_mod
