Rebuild errors, with attrsets and tensorflow
This error have blocked me.
[root@cynix:/etc/nixos]# nixos-rebuild switch
building Nix...
error:
         at /nix/store/b7fslslwv7xxgicazc77bbj3hxa2i817-nixos/nixos/lib/attrsets.nix:820:11:
          819|         || pred here (elemAt values 1) (head values) then
          820|           head values
          821|         else
         at /nix/store/b7fslslwv7xxgicazc77bbj3hxa2i817-nixos/nixos/lib/modules.nix:800:9:
          799|     in warnDeprecation opt //
          800|       { value = builtins.addErrorContext "while evaluating the option `${showOption loc}':" value;
          801|         inherit (res.defsFinal') highestPrio;
       error: Package ‘python3.10-tensorflow-2.11.1’ in /nix/store/b7fslslwv7xxgicazc77bbj3hxa2i817-nixos/nixos/pkgs/development/python-modules/tensorflow/default.nix:446 is marked as broken, refusing to evaluate.
       a) To temporarily allow broken packages, you can use an environment variable
          for a single invocation of the nix tools.
            $ export NIXPKGS_ALLOW_BROKEN=1
        Note: For `nix shell`, `nix build`, `nix develop` or any other Nix 2.4+
        (Flake) command, `--impure` must be passed in order to read this
        environment variable.
       b) For `nixos-rebuild` you can set
         { nixpkgs.config.allowBroken = true; }
       in configuration.nix to override this.
       c) For `nix-env`, `nix-build`, `nix-shell` or any other Nix command you can add
         { allowBroken = true; }
       to ~/.config/nixpkgs/config.nix.
How do I track down the problem?
You must be using python3Packages.tensorflow somewhere in your closure, which is currently broken on nixpkgs-unstable:
I don’t really have any mentions of python3Packages.tensorflow, so it must be some kind
of dependency.
Compiling retry.
building Nix...
error:
         at /nix/store/78ag6hsm2qimprlqlfm0p9gy88yzldas-nixos/nixos/lib/attrsets.nix:820:11:
          820|           head values
          821|         else
         at /nix/store/78ag6hsm2qimprlqlfm0p9gy88yzldas-nixos/nixos/lib/modules.nix:800:9:
       error: Package ‘python3.10-tensorflow-2.11.1’ in /nix/store/78ag6hsm2qimprlqlfm0p9gy88yzldas-nixos/nixos/pkgs/development/python-modules/tensorflow/default.nix:446 is marked as broken, refusing to evaluate.
Seems to included from this.
[root@cynix:/etc/nixos]# nix-store --query --referrers-closure  /nix/store/78ag6hsm2qimprlqlfm0p9gy88yzldas-nixos/
/nix/store/p7pzlm99h8gzlvf87p2vsmw8g16hv7r4-env-manifest.nix
/nix/store/vbj0w8bkz4blqapcrsllvkv1zv6bxsvp-user-environment
/nix/store/w2gywdgq6m2a8dx2irzs5fcilr69ba69-user-environment.drv
