Recommended approach for rootless podman-container with custom users?
I’m trying to create a rootless podman container with the following module:
{ root-domain, ... }:
  domain = root-domain;
  users = {
    users.website = {
      isSystemUser = true;
      home = "/var/lib/website/public";
      createHome = true;
      linger = true;
      group = "website";
    groups.website = { };
  virtualisation.oci-containers.containers.website = {
    image = "joseluisq/static-web-server:latest";
    podman.user = "website";
    volumes = [
      "/var/lib/website/public:/public:ro"
    labels = {
      "traefik.enable" = "true";
      "traefik.http.routers.website.rule" = "Host(`${domain}`)";
      "traefik.http.routers.website.service" = "website";
      "traefik.http.services.website.loadbalancer.server.port" = "80";
But if I execute nixos-rebuild build, I’m getting the following warning:
trace: evaluation warning: Podman container website is configured as rootless (user website)
with `--sdnotify=conmon`, but lingering for this user is turned on.
What is the recommended way to fix that?
Not an expert here, but often it’s worth to check the code
The warning is raised here nixpkgs/nixos/modules/virtualisation/oci-containers.nix at bfc1b8a4574108ceef22f02bafcf6611380c100d · NixOS/nixpkgs · GitHub
So the option in question is users.users.<name>.linger as far as I can see.
In your code you explicitly set linger to true, the module does not like that.
Yes, but if I’m understanding it correctly, I do require linger = true because otherwise a session wouldn’t be started during boot for the user, which also means that the container wouldn’t be able to do so.
Might worth to cross-check the blame of the code in question, maybe the PR adding that check give additional context.
Please choose the right branch for your channel, otherwise the code might be not up2date
What do you mean with “channel”? :eyes:
The release channel you use to build your system from, be it nixos-25.05, nixos-25.11, nixos-unstable or whatever else.
oh. Well then: I’m using nixos-25.11
25.11 has this:
on unstable this got removed in 2bf57f021280
You can try to use the unstable module, or a vendored stable version that has only the relevant changes. Alternatively you can change to unstable.
