Let’s say I have a pretty little derivation in default.nix
{ pkgs ? import <nixpkgs>{} } :
pkgs.stdenv.mkDerivation rec {
name = "xmonad-config";
src = ./.;
buildInputs = [ pkgs.ghc ];
installPhase = "cp ./xmonad.hs $out";
And then I want to a shell.nix
file, that contains all of the default.nix
goodies, but also some new features. What would I need to do to accomplish that? What way would you recommend?
The following code won’t work, but might help to give an understanding of what I want to do:
with import <nixpkgs> {};
default = pkgs.callPackage ./default.nix {};
shellHook = ''
echo 'Welcome to ${default.name}!';
echo 'Just look at all of the incredible buildInputs in default.nix we have:';
echo $buildInputs;
Should I use overlays somehow? If so, how?
I once came up with this structure (https://www.reddit.com/r/NixOS/comments/8tkllx/standard_project_structure/), I still use it as it helps me generate a Nixpkgs compliant derivation, override dependencies, and incorporate the overlay into configuariton.nix or nixops expressions as needed.
Thank you! Looks very interesting and I might start using that structure as well
But all of the files had examples except for shell.nix
. How would you write your shell.nix
if you need to inherit everything from default.nix
and just add, let’s say a new buildInput
item?
I’m a bit new to nix
so I’m not sure what’s best practice or even how you could do that
nix-shell
will use default.nix if shell.nix is not present. If you want to add something on top of default.nix for development purposes, there are two approaches:
- override the default.nix derivation
- create an environment using buildEnv
example of #2:
nixpkgs = import ./nixpkgs.nix;
pkgs = import nixpkgs {
config = {};
overlays = [
(import ./overlay.nix)
in pkgs.buildEnv {
name = "myEnv";
paths = [ pkgs.mySpecialPackage pkgs.someOtherDeveloptmentToolForNixShellOnly ];
Oh, I see, pkgs.buildEnv
looks like what I need! I’ll try it out, thanks a lot!
