Hi everyone!
At work, we have a huge monorepo and a frozen version of nixpkgs to build services and libraries. There’s a release.nix file containing all our packages and it’s very nice to know that if it can nix-build , then all the services compile and pass unit tests.
I’ve been trying to make our helper scripts reproducible by using nix-shell as a script interpreter. Unfortunately, there seems to be no way of pointing them to our frozen nixpkgs in a nice way. Given the following folder structure:
- nix
- nixpkgs
- default.nix # frozen nixpkgs
- bin
- helper-script.py
I can write a helper-script.py that looks like this:
#!/usr/bin/env nix-shell
#! nix-shell -I "nixpkgs=." -i python -p "python.withPackages (pkgs: [ pkgs.foo ])"
import foo
foo.blah()
…but it will only work if invoked from the nix directory as ./bin/helper-script.py . It would be really awesome if it was possible to specify pinned nixpkgs relative to the interpreted file if using nix-shell as an interpreter. In this way, no matter how we run that script, it would always resolve nixpkgs to what we have pinned right now.
I looked at the source code of nix-build (https://github.com/NixOS/nix/blob/master/src/nix-build/nix-build.cc#L111), and there seems no way to make it work now. Do you think adding a feature like that would be useful? How would it look?
…one idea I had is to introduce a new builtin - interpretedFile , that is only available when running nix-shell as interpreter. Since the value of <nixpkgs> is normally a path I want to import, I was wondering if I could make this work by putting a Nix expression in the -I :
#! nix-shell -I "nixpkgs=\"with builtins; (dirOf interpretedFile) + ../nixpkgs/\"" -i python -p "python.withPackages (pkgs: [ pkgs.foo ])"
If dirOf interpretedFile was aliased to something smaller, say <.>, we would be able to write:
#! nix-shell -I "nixpkgs=<.>/../nixpkgs" -i python -p "python.withPackages (pkgs: [ pkgs.foo ])"
