Hello,
I’m trying to use a remote nix machine to build a flake - ensuring that flake.lock
is honored and everything would be the same as if I did this locally. I’m on 22.05 with nix 2.9.0pre20220530_af23d38.
I want to build a container with nix and I have a (private) git repo with a flake similar to the following (and a flake.lock of course):
inputs.nixpkgs.url = "github:NixOS/nixpkgs/nixos-22.05";
outputs = { self, nixpkgs }:
pkgs = import nixpkgs {
system = "x86_64-linux";
python_env = pkgs.python39.withPackages (ps: with ps; [
numpy
container = pkgs.dockerTools.buildImage {
name = "cuda_py";
tag = "latest";
contents = with pkgs; [ busybox python_env ];
I can build this locally with nix build .#container
, but since I’ll be building some complex stuff, I want this to be built remotely. So I tried using
sudo nix store ping --store 'ssh://user@remote'
and it worked successfully. I can also run
sudo nix build --impure \
--expr '(with import <nixpkgs> { system = "x86_64-linux"; }; runCommand "foo" {} "uname > $out")' \
--builders 'ssh://user@remote x86_64-linux'
but when I try to build with the following command, it doesn’t work:
sudo nix build --builders 'ssh://user@remote x86_64-linux' .#container
it doesn’t work, and the problem is related to git:
warning: Not a git repository. Use --no-index to compare two paths outside a working tree
usage: git diff --no-index [<options>] <path> <path>
Diff output format options
-p, --patch generate patch
<cut>
--output <file> output to a specific file
error: program 'git' failed with exit code 129
… while fetching the input 'git+file:///home/user/path/to/project'
which… I don’t understand why is happening. The same thing happens if I try to build the project locally, but with sudo
$ sudo nix build --show-trace .#container
I’m not really understanding what is going on here: my guess is that when running with sudo
- as well as when running with the builder - it will try to fetch the repo via file path, which makes sense, but I don’t get why it’s not succeeding, and why is diff involved.
Can someone help me?
Thank you!
