I could use some help in investigating a problem. I’m not well versed with nixpkgs intricacies, so maybe someone here has an idea.
Since 25.05 my system has kwallet installed, seemingly via nextcloud-client.
$> nix why-depends --all .#melissa nixpkgs#kdePackages.kwallet
/nix/store/y40wlcvf3mxzq5j3v1a30y01gcbpannv-nixos-system-melissa-eisfunke-6977a94d9-dirty-25.05.20250612.fd48718
└───/nix/store/d39qg5j52rjnbhh832541nrs437ix4k2-etc
├───/nix/store/hfpii6xnbzx4s26mm2jhs001db49h151-user-environment
│ └───/nix/store/dh09jrhxs590kxh3nszsdkxx4b5w6pw8-home-manager-path
│ ├───/nix/store/by5z7x5gmisc3r11hq3n2ja5anrdz1lv-kwallet-6.14.0
│ ├───/nix/store/hfylsf8c1cs4x9l1yvvlrmlhrcgdbnkv-kio-6.14.0
│ │ └───/nix/store/by5z7x5gmisc3r11hq3n2ja5anrdz1lv-kwallet-6.14.0
│ └───/nix/store/v0dqs88n707j46c6nlypxcvr5bp5ysff-nextcloud-client-3.16.4
│ └───/nix/store/hfylsf8c1cs4x9l1yvvlrmlhrcgdbnkv-kio-6.14.0
└───/nix/store/6xm8h1qyv7z6nrzjkqckj48jq9x9szg6-system-units
└───/nix/store/x7vj13711szl23i2y43qly3ajprcisb4-unit-home-manager-eisfunke.service
└───/nix/store/w3njhwqpwrjm2jdakf3c5yg4s6q5brmq-home-manager-generation
├───/nix/store/dh09jrhxs590kxh3nszsdkxx4b5w6pw8-home-manager-path
└───/nix/store/1660yf3xq30s1phazgdhkcag0b8xiwaz-home-manager-files
└───/nix/store/c5y3i6qwbbr8h1624x5xcjz2mszlyz5d-hm_fontconfigconf.d10hmfonts.conf
I’m not entirely sure that it wasn’t included before 25.05, but since that update some applications started trying to use/launch kwallet, which is why I noticed it being installed.
I don’t want kwallet, as I’m already using gnome-keyring and I don’t want applications to attempt to use the other secret manager. I don’t think it makes much sense for nextcloud-client to depend directly on kwallet anyway, because it uses gnome-keyring just fine. Installing a secret manager should be task of the overarching system, not a direct dependency of the package, I’d say.
So I tried to find out why it’s there and how to get rid of it. It looks like it’s pulled in via kio?
$> nix why-depends --all nixpkgs#nextcloud-client nixpkgs#kdePackages.kwallet
Which makes sense to me, because the nextcloud-client package.nix pulls in kdePackages.kio.
I fail to understand why kio depends on kwallet though. Its default.nix doesn’t reference kwallet or even kdePackages at all. It uses mkKdeDerivation, which seems to be defined here, but that doesn’t reference kdePackages or kwallet either.
What am I missing? Where does the kwallet depenency come from?
(Btw, getting rid of it in my system closure by overriding kwallet with null or a placeholder didn’t work, presumably because it’s pulled in through kio? And I can’t override the kwallet input of kio because it doesn’t have one…)
