Resolution problem with external Monitor connected via dock after update
Hi,
I have a ThinkPad T14 Gen4 (AMD Ryzen 5 Pro 7540U) with a ThinkPad Universal USB-C dock. Attached to the dock are two 4K 60Hz monitors via DP and Gnome (X11 and Wayland) or Sway as WM.
I used nixos-unstable with flakes. After a flake update and the following rebuild, I can no longer use my external monitors with 4k 60Hz resolution. Lowering the resolution to 1080p or reducing the refresh rate to 30Hz solves the problem. If I roll back to a previous configuration/build, everything is fine.
I tried things I found online, like DisplayLink or not working docks, changing the USB port, but none seems to be the solution. boltctl isn’t showing anything, but I would guess my dock is working, as the monitors are detected and my Ethernet connection is working.
Finally, I tried to “downgrade” my system to nixos-24.04, but the issue still exists. I tried to diff my configuration, but out of noobieness, I don’t have the system.copySystemConfiguration set to true, nor I committed my changes in git. Manually checking the config and figuring out what could be the problem wasn’t helpful.
I’m really new to the whole NixOS world, and I would be happy if we could figure out, what the problem is. Thanks!
I don’t have a solution but I can confirm the same problem. I’m on a T14 Gen 4 with a USB-C dock. I have one external monitor which is 5120 x 1440 via DP and it just broke when I updated this evening. Plug the monitor in via the dock and it is detected but nothing displays. I am using 24.05 with flakes. I had to get some work done and reverting to the previous build fixed everything so I haven’t had time to investigate further at this point.
I also have this problem, but if I choose the selected resolution or lower, it does work.
Could you try the same and see if lower resolutions still work via the dock? It feels to me its something like bandwidth related?
Hi,
yes, lowering the resolution or lowering the refresh rate solves the problem. Bandwidth sounds reasonable. If I try to set a resolution above this bandwidth, it even says that my hardware does not support it. Even though it was possible in the past. I also tried to disconnect other devices from the dock to reduce the traffic a check if this changes something, but without any success.
I think this is a kernel bug. If I update but pin the kernel to 6.10.11 everything is fine. If I let it update to the latest which is 6.11 it breaks.
