Running and diagnosing package passthru tests
Hello, sorry if this seems like a noob question, but how can I run the passthru tests of a particular package and how should I go for diagnosing problems with the tests?
Currently, there’s this PR that is being held by what I think is a faulty test: vcpkg-tool-unwrapped: 2025-05-19 -> 2025-06-20 by r-ryantm · Pull Request #413467 · NixOS/nixpkgs · GitHub
I can see the tests being defined here, but I don’t know how to run locally it or see the exact reason why it fails: nixpkgs/pkgs/by-name/vc/vcpkg-tool/package.nix at 4e806e6f5efc0b4cb9906e3f5542883d179ce2d1 · NixOS/nixpkgs · GitHub
Any help would be greatly appreciated!
Tests are derivations too; you can just run (from a local Nixpkgs tree) nix-build . -A vcpkg-tool-unwrapped.tests. Tests are generally written such that ‘failure’ means they won’t build.
It looks like the test should be disabled if doWrap is false, since the test is testing the wrapper.
That would explain why the test seemingly worked when looking at the logs for the wrapped version. Thank you for the tip!
