Run the file with nix-shell and you’ll get into a shell where you can just run the binary.
You can run the binary instead of entering into the shell by adding shellHook = <command> into the nix file. And you can move the nix file into $HOME/.local/nix-shell/, create $HOME/.local/bin/<name> with exec nix-shell $HOME/.local/nix-shell/<filename>.nix in it, add $HOME/.local/bin/ to the $PATH and voilà.
I mean that the rpath of an executable will have a lower priority then LD_LIBRARY_PATH, which might be a problem if you try to run an executable that is linked against an older library, because LD_LIBRARY_PATH would force the newer version.
If a shared object dependency does not contain a slash, then it is
searched for in the following order:
Using the directories specified in the DT_RPATH dynamic section
attribute of the binary if present and DT_RUNPATH attribute does
not exist. Use of DT_RPATH is deprecated.
Using the environment variable LD_LIBRARY_PATH, unless the
executable is being run in secure-execution mode (see below), in
which case this variable is ignored.
Using the directories specified in the DT_RUNPATH dynamic section
attribute of the binary if present. Such directories are searched
only to find those objects required by DT_NEEDED (direct
dependencies) entries and do not apply to those objects’ children,
which must themselves have their own DT_RUNPATH entries. This is
unlike DT_RPATH, which is applied to searches for all children in
the dependency tree.
From the cache file /etc/ld.so.cache, which contains a compiled
list of candidate shared objects previously found in the augmented
library path. If, however, the binary was linked with the -z
nodeflib linker option, shared objects in the default paths are
skipped. Shared objects installed in hardware capability
directories (see below) are preferred to other shared objects.
In the default path /lib, and then /usr/lib. (On some 64-bit
architectures, the default paths for 64-bit shared objects are
/lib64, and then /usr/lib64.) If the binary was linked with the
-z nodeflib linker option, this step is skipped.
So if nix indeed sets RPATH instead of RUNPATH, everything should be fine.
UPDATE:
This is unlike DT_RPATH, which is applied to searches for all children in the dependency tree.
Oh. So nix indeed should set RUNPATH. All right, there’s indeed a problem with using LD_LIBRARY_PATH.
