I am trying to build a nix flake for TI’s Code Composer Studio which has a binary installer.
That installer extracts some shell scripts that has some hardcoded paths inside.
So far I was able to run the installer in steam-run and it works but I can not run that in the flake as it can not find libcrypt.
Patching the installer binary gets me to the scripts with the hardcoded paths, which I can not path as they are extracted and executed from the installer.
What would be the best way to work around this?
You might need libxcrypt-legacy.
Thanks that helped, I had to add some other libraries
Hi, did you publish your solution somewhere? I would like to do the same thing (i.e., install TI Code Composer Studio).
thanks in advance
I got it running with steam-run. Can post my solution later
that would be very helpful. thank you
not my best nix flake but it works. Suggestion are very welcome.
replace <your_cpu> and <your_required_library> as you need it.
flake.nix
description = "CodeComposerStudio";
nixpkgs.url = "github:NixOS/nixpkgs";
outputs = {self, nixpkgs}: {
packages.x86_64-linux= {
CodeComposerStudio =
with import nixpkgs {
system = "x86_64-linux";
config.allowUnfree = true;
config.permittedInsecurePackages = [
"python-2.7.18.7"
config.packageOverrides = pkgs: {
steam = pkgs.steam.override {
extraPkgs = pkgs: with pkgs; [
libxcrypt-legacy
python2
ncurses5
libusb-compat-0_1
stdenv.mkDerivation rec {
name = "CodeComposerStudio-${version}";
version = "12.6.0";
build = "00008";
src = pkgs.fetchurl {
url = "https://dr-download.ti.com/software-development/ide-configuration-compiler-or-debugger/MD-J1VdearkvK/${version}/CCS${version}.${build}_linux-x64.tar.gz";
sha256 = "sha256-UBzThgBSy5oJfIZGE5RgMlVkCNh/16jtoYF/J0INBOc=";
desktopItem = makeDesktopItem {
type = "Application";
terminal = false;
name = "Code Composer Studio";
exec = "ccs";
icon = "ccs";
comment = "Texas Instruments Code Composer Studio";
desktopName = "Code Composer Studio";
genericName = "Code Composer Studio";
categories = [ "Development" ];
buildInputs = [
openssl
zlib
glib
jdk
unzip
steam-run
sourceRoot = ".";
installPhase = ''
runHook preInstall
steam-run ./CCS${version}.${build}_linux-x64/ccs_setup_${version}.${build}.run --mode unattended --enable-components <your_cpu> --prefix /build/ti/
# compile the libraries for your target arch
PATH=/build/ti/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin:$PATH steam-run /build/ti/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/lib/mklib --pattern <your_required_library>.lib
mv /build/ti $out
mkdir -p $out/share/icons
ln -s $out/ccs/doc/ccs.ico $out/share/icons/ccs.ico
mkdir -p $out/share/applications
cp ${desktopItem}/share/applications/* $out/share/applications
mkdir -p $out/bin
echo "#! /usr/bin/env bash" > $out/bin/ccs
echo "steam-run $out/ccs/eclipse/ccstudio" >> $out/bin/ccs
chmod oug+x $out/bin/ccs
meta = with lib; {
homepage = "https://ti.org";
platforms = platforms.linux;
default = self.packages.x86_64-linux.CodeComposerStudio;
Please note that steam-run just exposes the fhsenv used by steam for use via interactive shell. If you’re packaging something, it’s better to use buildFHSEnv directly.
However, (buildFHSEnv { }).env.stdenv.mkDerivation still doesn’t have fhsenv. only /bin/sh
Related: Package request: ccstudio · Issue #363998 · NixOS/nixpkgs · GitHub
Yes, I’m not aware of such a handy wrapper; you have to run it manually.
