I am trying to set up Nixos with Hyprland on my Lenovo Yoga Pro 7 14IMH9.
The laptop has an nvidia rtx 3060 graphics card. I don’t know if the drivers aren’t working (even though I tried following the documentation and tried out numerous configurations suggested by peers and threads online) or if the issue lies somewhere else. (if it is the later, it probably has something to do with hyprland, since other window managers work fine)
Tried using gnome and sway to check wether they would work, they worked perfectly fine. When using hyprland however, I run into the following issue:
Every window starts flickering, not just around the borders but everywhere.
Also I wanted to point out since I found that to be strange but idk if it helps: I tried recording and there seemed to be no flickering while selecting the screen to record from, however while actually recording the screen everything was flickering weirdly again. (Also I couldn’t get the recording to save, I can retry if needed)
This is the output from lspci:
00:00.0 Host bridge: Intel Corporation Device 7d01 (rev 04)
00:01.0 PCI bridge: Intel Corporation Device 7ecc (rev 10)
00:02.0 VGA compatible controller: Intel Corporation Meteor Lake-P [Intel Arc Graphics] (rev 08)
00:04.0 Signal processing controller: Intel Corporation Meteor Lake-P Dynamic Tuning Technology (rev 04)
00:06.0 PCI bridge: Intel Corporation Device 7eca (rev 10)
00:07.0 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 10)
00:08.0 System peripheral: Intel Corporation Meteor Lake-P Gaussian & Neural-Network Accelerator (rev 20)
00:0a.0 Signal processing controller: Intel Corporation Meteor Lake-P Platform Monitoring Technology (rev 01)
00:0b.0 Processing accelerators: Intel Corporation Meteor Lake NPU (rev 04)
00:0d.0 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 USB Controller (rev 10)
00:0d.2 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 NHI #0 (rev 10)
00:12.0 Serial controller: Intel Corporation Meteor Lake-P Integrated Sensor Hub (rev 20)
00:14.0 USB controller: Intel Corporation Meteor Lake-P USB 3.2 Gen 2x1 xHCI Host Controller (rev 20)
00:14.2 RAM memory: Intel Corporation Device 7e7f (rev 20)
00:14.3 Network controller: Intel Corporation Meteor Lake PCH CNVi WiFi (rev 20)
00:15.0 Serial bus controller: Intel Corporation Meteor Lake-P Serial IO I2C Controller #0 (rev 20)
00:15.1 Serial bus controller: Intel Corporation Meteor Lake-P Serial IO I2C Controller #1 (rev 20)
00:15.3 Serial bus controller: Intel Corporation Meteor Lake-P Serial IO I2C Controller #3 (rev 20)
00:16.0 Communication controller: Intel Corporation Meteor Lake-P CSME HECI #1 (rev 20)
00:1f.0 ISA bridge: Intel Corporation Device 7e02 (rev 20)
00:1f.3 Multimedia audio controller: Intel Corporation Meteor Lake-P HD Audio Controller (rev 20)
00:1f.4 SMBus: Intel Corporation Meteor Lake-P SMBus Controller (rev 20)
00:1f.5 Serial bus controller: Intel Corporation Meteor Lake-P SPI Controller (rev 20)
01:00.0 3D controller: NVIDIA Corporation AD107M [GeForce RTX 4060 Max-Q / Mobile] (rev a1)
06:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9C1a (DRAM-less)
I’ve tried numerous configurations however none of them proved successful in terminating the described issue.
If anyone has a working nix configuration for this machine or could help me in any way, I’d greatly appreciate that. Thank you.
