Running python scripts (works different in config than in shell)
Summary
Hi! I use kde plasma & hyprland /w waybar. which is not really that important to this.
I am on the unstable channel if that matters.
when configuring waybar, I found something online that I wanted and it required a python script. it did not work out of the box, so I made a nix shell to troubleshoot. once I got it working, I ported the exact same packages I used in the shell to my hyprland configuration nix file. but for some reason, it didn’t work.
judging from the error message, it doesn’t even see one of the packages.
what happens in shell (expected):
{"text": "\uf144                   ", "class": "perc0-0", "tooltip": "<span></span>"}
it would show more if I had music playing
what happens outside of shell (unexpected):
  File "/home/<user>/.config/waybar/waybar-mediaplayer/src/./mediaplayer", line 26, in <module>
    gi.require_version("Playerctl", "2.0")
  File "/nix/store/flawsk5hh9zizcds4cvlp36dr3cp2dy9-python3-3.12.9-env/lib/python3.12/site-packages/gi/__init__.py", line 122, in require_version
    raise ValueError('Namespace %s not available' % namespace)
ValueError: Namespace Playerctl not available
with name redacted, of course.
entire shell:
  pkgs = import <nixpkgs> {};
in pkgs.mkShell {
  packages = [
    (pkgs.python312.withPackages (python-pkgs: with python-pkgs; [
      pandas
      requests
      syncedlyrics
      pillow
    (pkgs.python312Packages.pygobject3)
    (pkgs.playerctl)
entire Hyprland config (nix):
# This is the nix hyprland configuration file  #
# use it to declare packages and edit hyprland #
{ pkgs, ... }:
  programs.hyprland = {
    # Install the packages from nixpkgs
    # Whether to enable XWayland
    xwayland.enable = true;
    feh
    font-awesome
    foot
    gnome-keyring
    hyprcursor
    hyprgraphics
    hypridle
    hyprland-qt-support
    hyprland-qtutils
    hyprlang
    hyprlock
    hyprls
    hyprpaper
    hyprpicker
    hyprpolkitagent
    hyprshade
    hyprsunset
    hyprsysteminfo
    hyprutils
    hyprwayland-scanner
    iwd
    iwgtk
    kitty
    mako
    mpv
    pavucontrol
    playerctl
    (python312.withPackages (python-pkgs: with python-pkgs; [
      pandas
      requests
      syncedlyrics
      pillow
      pygobject3
    waybar
    wlogout
    wofi
    xdg-desktop-portal-hyprland
running python script throws an error when ran outside a shell even though the shell I originally ran it in and my main config have the same packages.
related shell packages:
in pkgs.mkShell {
  packages = [
      pandas
      requests
      syncedlyrics
      pillow
    (pkgs.playerctl)
related config packages:
    playerctl
      pandas
      requests
      syncedlyrics
      pillow
      pygobject3
any help would be appreciated.
Shells set certain envvars that would not be set globally. If you want a script to work, package it with nix, rather than randomly installing dependencies and hoping the script finds them. See https://nixos.org/manual/nixpkgs/unstable/#python.
first I’ll need to find out how to do that, but I am going to try it. thank you for helping.
just packaged it up, and I’m getting the same error. any idea what variables I need to change? or at least how to find out what variables are changed in a shell compared to nixos?
Share what you tried.
python script
# waybar-mediaplayer-script
#!/usr/bin/env python3
# Copyright 2024 Raffaele Mancuso
# SPDX-License-Identifier: MIT
# Inspired by: https://github.com/Alexays/Waybar/blob/
#              master/resources/custom_modules/mediaplayer.py
import argparse
import io
import json
import logging
import math
import re
import shutil
import subprocess
import sys
import time
import urllib
from collections import namedtuple
from functools import partial
from pathlib import Path
import gi
import requests
import syncedlyrics
from PIL import Image
from gi.repository import GLib, Playerctl  # noqa: E402
# Internal global variables
config = None
logger = logging.getLogger(__name__)
artfp = Path("/tmp/waybar-mediaplayer-art")
last_metadata = None
last_art_url = None
last_rot = 0
last_rot_time = 0
last_notification_time = 0
# Whether refresh_interval callback is registered
is_refint = False
format_class = None
icons = {"play": " ", "stop": " "}
is_text_rotating = None
lyrics = dict()
def on_player_appeared(manager, player, requested_player):
    logger.debug("I was called")
    if player and (player.name == requested_player):
        init_player(manager, player)
    else:
        logger.debug(
            "New player appeared, but it's not the selected player, skipping"
    logger.debug("Returning True")
    return True
def delete_album_art():
    p = Path(__file__)
    if config["album_art_placeholder"] == "dark":
        phfp = p.parents[1] / "assets" / "music_black.png"
    elif config["album_art_placeholder"] == "light":
        phfp = p.parents[1] / "assets" / "music_white.png"
    elif config["album_art_placeholder"] == "no":
        phfp = None
    else:
        raise Exception(
            f"ERROR: Invalid value {config['album_art_placeholder']} "
            "for `album_art_placeholder` option"
    if phfp:
        shutil.copy(phfp, artfp)
    else:
        if artfp.is_file():
            artfp.unlink()
    signal_album_art_change()
def on_player_vanished(manager, player):
    logger.info("I was called")
    write_output()
    delete_album_art()
    logger.info("Returning True")
    return True
def on_metadata(player, metadata, manager):
    update_metadata(player, metadata, manager)
    return True
def on_playback_status(player, status, manager):
    logger.debug(f"status={status}")
    # Update the icon in the progressbar (play/pause)
    logger.debug("Calling register_refresh_interval_callback")
    register_refresh_interval_callback(player, manager)
    logger.debug("Calling update_progressbar")
    update_progressbar(manager, player)
    return True
def on_refresh_interval(manager):
    global is_refint
    # If there are no players, stop calling this handler
    if len(manager.props.players) == 0:
        logger.debug("Returning False")
        is_refint = False
        return False
    player = manager.props.players[0]
    # If we are not playing, stop calling this handler
    is_playing = player.props.status == "Playing"
    if not is_playing:
        is_refint = False
        return False
    # Update progressbar and return
    return True
def write_output(text=None, class_=None, tooltip=""):
    global config
    # Default values if not explicitly set
    if not text:
        text = "" + (" " * (config["widget_length"] - 1))
    if not class_:
        class_ = gen_class(0.0)
    if not tooltip:
        tooltip = ""
    # HTML entities need to be escaped
    text = text.replace("&", "&amp;")
    tooltip = tooltip.replace("&", "&amp;")
    # Write to stdout
    output = {
        "text": text,
        "class": class_,
        "tooltip": "<span>" + tooltip + "</span>",
    sys.stdout.write(json.dumps(output) + "\n")
    sys.stdout.flush()
def register_refresh_interval_callback(player, manager):
    global is_refint
    if is_playing and (not is_refint):
        logger.debug("Registering `refresh_interval` callback")
        GLib.timeout_add(
            config["refresh_interval"], on_refresh_interval, manager
        is_refint = True
def rotate_str_left(s, rot):
    return s[rot:] + s[:rot]
def gen_widget_text(player):
    global last_rot, last_rot_time, is_text_rotating
    metadata = player.props.metadata
    # artist = player.get_artist()
    # artist = metadata["xesam:artist"][0]
    title = player.get_title() or ""
    # title = metadata["xesam:title"]
    icon = icons["play"] if player.props.status != "Playing" else icons["stop"]
    if (
        player.props.player_name == "spotify"
        and "mpris:trackid" in metadata.keys()
        and ":ad:" in metadata["mpris:trackid"]
        song_info = "AD PLAYING"
    else:
        song_info = title.strip()
    if not is_text_rotating:
        text = left_text(icon + song_info)
    else:
        song_info += " " + config["sepchar"] + " "
        elapsed = (time.time() - last_rot_time) * 1000
        rot_needs_update = elapsed > config["text_rot_int"]
        if rot_needs_update:
            to_add = math.floor(elapsed / config["text_rot_int"])
            l_rot = (last_rot + to_add) % len(song_info)
            last_rot = l_rot
            last_rot_time = time.time()
        else:
            l_rot = last_rot
        song_info = rotate_str_left(song_info, l_rot)
        text = icon + song_info
    return text
def signal_album_art_change():
    cmd = ["pkill", "-RTMIN+" + str(config["image_signal"]), "waybar"]
    res = subprocess.run(cmd)
    logger.debug(f"pkill returned: {res}")
def download_art(art_url):
    logger.debug("Updating album art")
    if art_url.startswith("http"):
        resp = requests.get(art_url)
        with open(artfp, "wb") as fh:
            fh.write(resp.content)
        logger.debug(
            f"Album art '{art_url}' downloaded and saved into '{artfp}'"
    elif art_url.startswith("file://"):
        art_url = art_url[7:]
        art_url = urllib.parse.unquote(art_url)
        # symlinking the file doesn't work
        # apparently symlinks are not followed
        # artfp.symlink_to(art_url)
        shutil.copy(art_url, artfp)
        logger.debug(f"Album art '{art_url}' copied to '{artfp}'")
    elif Path(art_url).is_file():
    else:
        logger.debug(
            f"Invalid schema for {art_url}. Please report this as a bug."
        return
    # Convert image to JPEG
    if config["convert_to_jpeg"]:
        artfp2 = artfp.parent / (artfp.stem + ".jpeg")
        with Image.open(artfp) as im:
            im.save(artfp2)
        shutil.move(artfp2, artfp)
    # Update album art on bar
def send_notification(summary, body):
    global last_notification_time
    cmd = [
        "notify-send",
        "--app-name=waybar-mediaplayer",
        "--icon=" + artfp,
        summary,
        body,
    logger.error(f"Running {cmd}")
    subprocess.run(cmd)
    last_notification_time = time.time()
def update_metadata(player, metadata, manager):
    global last_notification_time, last_art_url, is_text_rotating
    metadata = dict(metadata)
    updated = update_progressbar(manager, player)
    if not updated:
        logger.debug("Progress bar not updated. Returning")
        return False
    # Download album art
    art_url = metadata.get("mpris:artUrl", None)
    if art_url and art_url != last_art_url:
        last_art_url = art_url
    # Notification
    notexp = time.time() - last_notification_time
    if config["is_notification"] and (
        notexp >= config["notification_min_interval"]
        send_notification(player.get_title(), player.get_artist())
    # Does text need rotation?
    is_text_rotating = (
        len(title) + len(icons["stop"]) + 1 > config["widget_length"]
    # Lyrics
    artist = player.get_artist() or ""
    get_new_lyrics(artist, title)
    logger.debug("Returning")
def download_lyrics(artist, title):
    stream = io.StringIO()
    lyrlogger = syncedlyrics.logger
    lyrlogger.propagate = False
    lyrlogger.handlers.clear()
    lyrlogger.addHandler(logging.StreamHandler(stream))
    lyrlogger.setLevel(logging.INFO)
    try:
        lt = syncedlyrics.search(
            f"{artist} {title}",
            synced_only=True,
            providers=config["lyrics_providers"],
    except Exception:
        logger.debug(
            "ERROR: syncedlyrics.search threw an exception. Returning None.")
        return None
    if lt is None:
        logger.debug(
            "ERROR: syncedlyrics.search returned None. Returning None.")
        return None
    lt = lt.replace("\n", "")
    lt = lt.split("[")
    lt = ["["+x for x in lt if x]
    provider = stream.getvalue().split("on ")[1].strip()
    stream.close()
    SyncedLyrics = namedtuple("SyncedLyrics", ["lt", "provider"])
    return SyncedLyrics(lt, provider)
def get_new_lyrics(artist, title):
    global lyrics
    lyrics = {
        "secs": [0],
        "text": ["[INTRO]"],
        "last_ix": -1,
        "max_len": 0,
        "provider": None,
    lyr = download_lyrics(artist, title)
    if lyr is None:
        logger.debug("ERROR: download_lyrics returned None. Returning.")
        lyrics = None
        return
    lyrics["provider"] = lyr.provider
    for i, line in enumerate(lyr.lt):
        m = re.match(r"\[(.*)\](.*)", line)
        if not m:
            continue
        # convert time from min:sec into sec
        timing = m.group(1)
        timing2 = timing.split(":")
        if len(timing2) != 2:
            logger.debug(f"ERROR: timing2={timing2} is not of length 2")
            continue
        try:
            secs = int(timing2[0]) * 60.0 + float(timing2[1])
        except ValueError:
            logger.debug(f"ERROR: ValueError while converting timing2={
                         timing2} to seconds")
            continue
        # get lyrics text
        text = m.group(2).strip()
        if text == "":
            text = "[INTERMISSION]"
        lyrics["secs"].append(secs)
        lyrics["text"].append(text)
        lyrics["max_len"] = max(lyrics["max_len"], len(text))
        # DEBUG
        logger.debug(str(i) + str(line) + "->" + "[" + str(secs) + "] " + text)
    lyrics["text"].append("[OUTRO]")
    lyrics["secs"].append(lyrics["secs"][-1] + 1)
def left_text(s):
    le = len(s)
    if le > config["widget_length"]:
        return s
    missing = config["widget_length"] - le
    s = s + " " * (missing)
    return s
def center_text(s, ml=None):
    if not ml:
        ml = max([len(x) for x in s])
    for i in range(0, len(s)):
        delta = max(math.floor((ml - len(s[i])) / 2), 0)
        s[i] = (" " * delta) + s[i] + (" " * delta)
    return s
def gen_class(perc):
    if not isinstance(perc, float):
        raise Exception(f"{perc} ({type(perc)}) is not a float")
    return "perc" + format_class(perc).replace(".", "-")
# Called
# 1. By `on_refresh_interval`
# 2. By `on_metadata`
# 3. By `on_playback_status`
def update_progressbar(manager, player):
    global last_metadata, lyrics
    # Get percentage in the track
    pos = player.get_position()
    logger.debug(f"pos={pos}")
    # If it doesn't work, use CLI utility
    if pos == 0:
        cmd = ["playerctl", "--player=" + player.props.player_name, "position"]
        pos = subprocess.run(cmd, capture_output=True, text=True).stdout
        pos = float(pos) * (10**6)
        logger.debug(f"pos from CLI={pos}")
    pmetadata = player.props.metadata
    logger.debug(f"pmetadata={pmetadata}")
    try:
        # cast to int is important as some softwares,
        # like Amberol, are reporting a string
        # If the length of the track is known,
        # it should be provided in the metadata property
        # with the "mpris:length" key.
        # The length must be given in microseconds,
        # and be represented as a signed 64-bit integer
        # see: https://specifications.freedesktop.org/mpris-spec/2.2/Track_List_Interface.html # noqa: E501
        length = int(pmetadata["mpris:length"])
    except KeyError:
        logger.debug(
            "ERROR: The player is not reporting the length of the song to us. "
            "Progress bar won't work."
        length = 100
        pos = 0
    else:
        logger.debug(f"length={length}")
        if length == 0:
            logger.debug(
                "ERROR: Length of song is 0. Progress bar won't work."
            length = 100
            pos = 0
    # Compute song percentage
    perc = (pos / (length / config["length_factor"])) * 100
    perc = min(perc, 100.0)
    metadata = {
        "title": player.get_title() or "",
        "artist": player.get_artist() or "",
        "album": player.get_album() or "",
        "pos": pos,
        "length": length,
        "perc": perc,
    # Check if a rotating text needs to be updated
    # Check if progress bar needs to be updated
    diff = metadata["perc"] - last_metadata["perc"] if last_metadata else 99999
    pbar_needs_update = diff > config["interval"]
    # Check if lyrics needs an update
    if lyrics:
        # pos is in microseconds
        lyr_pos = float(pos / (10**6))
        lyrics_ix = sum(lyr_pos >= x for x in lyrics["secs"]) - 1
        lyrics_same = lyrics_ix == lyrics["last_ix"]
    else:
        lyrics_same = True
    # Check if song is the same (otherwise text needs to be updated)
    same_song = (
        last_metadata
        and metadata["title"] == last_metadata["title"]
        and metadata["artist"] == last_metadata["artist"]
        and metadata["album"] == last_metadata["album"]
        and metadata["length"] == last_metadata["length"]
        and lyrics_same
    # Check if we need to update
    if same_song and \
            not pbar_needs_update and \
            not rot_needs_update:
        logger.debug(
            "Song is the same and neither the text "
            "nor the progressbar nor the lyrics needs an update. Returning"
        return False
    # Write output
    # - Widget text
    widget_text = gen_widget_text(player)
    # - Tooltip text
    s = [metadata["title"], metadata["artist"], metadata["album"]]
    # -- Lyrics
    curr_line = None
    text_len = None
    if lyrics:
        cand = [len(x) for x in s]
        cand.append(lyrics.get("max_len", 3))
        text_len = max(cand)
        s.append("-" * text_len)
        provider = lyrics.get("provider", "")
        if provider is None:
            provider = "NO PROVIDER"
        s.append("["+provider+"]")
        # DEBUG
        # print(f"lyrics['secs']={lyrics['secs']}")
        # print(f"pos={pos}; length={length}")
        # print(f"lyr_pos={lyr_pos}; lyrics_ix={lyrics_ix}")
        lyrics["last_ix"] = lyrics_ix
        span_before = config["lyrics_span_before"]
        span_after = config["lyrics_span_after"]
        # Make sure we always have the same number of lines
        # also at start and end of the song
        span_before += max(lyrics_ix + span_after - len(lyrics["text"]) + 1, 0)
        span_after += max(span_before - lyrics_ix, 0)
        # Loop over lyrics window
        to_put = range(
            max(lyrics_ix - span_before, 0),
            min(lyrics_ix + span_after, len(lyrics["text"]) - 1) + 1,
        for t in to_put:
            s.append(lyrics["text"][t])
            if t == lyrics_ix:
                curr_line = len(s) - 1
    # -- Tooltip
    center_text(s, text_len)
    if curr_line:
        s[curr_line] = "<b>" + s[curr_line] + "</b>"
    tooltip = f"<span variant='title-caps' font_weight='bold'>{s[0]}</span>"
    tooltip += f"\n{s[1]}"
    # Skip album in tooltip if we don't have it
    s[2] = s[2].strip()
    if s[2]:
        tooltip += f"\n<i>{s[2]}</i>"
    if len(s) >= 4 and s[3].strip():
        tooltip += "\n"
        tooltip += "\n".join(s[3:])
    write_output(widget_text, gen_class(perc), tooltip)
    # It's important to return True to keep the handler going
    last_metadata = metadata
    return True
def init_player(manager, name):
    logger.debug(f"name.name={name.name}")
    # Register handlers
    player = Playerctl.Player.new_from_name(name)
    player.connect("playback-status", on_playback_status, manager)
    player.connect("metadata", on_metadata, manager)
    manager.manage_player(player)
    # Call update_metadata to update progress bar and send notification
    logger.debug("Calling update_metadata")
    update_metadata(player, player.props.metadata, manager)
    # If we are playing, register refresh interval callback
    logger.debug("Returning None")
def signal_handler(sig, frame):
    sys.stdout.write("\n")
    sys.stdout.flush()
    # loop.quit()
    sys.exit(0)
def parse_arguments():
    parser = argparse.ArgumentParser()
    # Increase verbosity with every occurrence of -v
    parser.add_argument("command", action="store", default="error")
    parser.add_argument("-v", "--verbose", action="count", default=0)
    return parser.parse_args()
def main():
    arguments = parse_arguments()
    # Initialize logging
    logging.basicConfig(
        stream=sys.stderr,
        level=logging.DEBUG,
        format="[%(name)s] [%(funcName)s] [%(levelname)s] %(message)s",
    # Logging is set by default to WARN and higher.
    # With every occurrence of -v it's lowered by one
    # until it reaches 0
    loglevel = max((3 - arguments.verbose) * 10, 0)
    logger.setLevel(loglevel)
    logging.getLogger("urllib3").setLevel(loglevel)
    logging.getLogger("syncedlyrics").setLevel(loglevel)
    # Log the sent command line arguments
    logger.debug("Arguments received {}".format(vars(arguments)))
    # Read configuration from file
    fp = Path(sys.argv[0]).parent.resolve() / "config.json"
    if not fp.is_file():
        logging.critical(f"ERROR: Configuration file {fp} not found")
        sys.exit(1)
    with open(fp, "r") as fh:
        global config
        config = json.load(fh)
    logger.debug(f"config={config}")
    assert isinstance(config, dict)
    # Remove album art if present
    delete_album_art()
    # Function to generate CSS classes
    global format_class
    interval = config["interval"]
    digits = math.floor(math.log10(interval))
    digits = max(0, math.fabs(digits))
    digits = int(digits)
    format_class = partial(lambda x, y: str(round(x, y)), y=digits)
    manager = Playerctl.PlayerManager()
    requested_player = config["player_name"].split(".")[0]
    logger.debug(
        f"Splitting player_name on `.`. requested_player={requested_player}"
    ini = False
    for player in manager.props.player_names:
        logger.debug(f"Found player '{player.name}'")
        if not player.name.startswith(requested_player):
            logger.debug("This is not the filtered player, skipping it")
            continue
        if arguments.command == "play-pause":
            Playerctl.Player.new(player.name).play_pause()
            sys.exit(0)
        elif arguments.command == "next":
            Playerctl.Player.new(player.name).next()
            sys.exit(0)
        elif arguments.command == "previous":
            Playerctl.Player.new(player.name).previous()
            sys.exit(0)
        elif arguments.command == "monitor":
            logger.debug("Initializing player")
            ini = True
        else:
            logger.critical(f"Invalid argument {sys.argv[1]}")
            sys.exit(1)
    if not ini:
        logger.debug("No player found. Printing empty")
        write_output()
    loop = GLib.MainLoop()
    on_player_appeared_inst = partial(
        on_player_appeared, requested_player=requested_player
    # manager.connect("player-appeared", on_player_appeared)
    manager.connect("name-appeared", on_player_appeared_inst)
    manager.connect("player-vanished", on_player_vanished)
    # signal.signal(signal.SIGINT, signal_handler)
    # signal.signal(signal.SIGTERM, signal_handler)
    # signal.signal(signal.SIGPIPE, signal.SIG_DFL)
    loop.run()
if __name__ == "__main__":
    main()
#waybar-media-player.nix
{ pkgs, python3Packages}:
python3Packages.buildPythonApplication rec {
    pname = "waybar-mediaplayer-script";
    version = "0.0.1";
    pyproject = false;
    propagatedBuildInputs = with pkgs; [
        python3Packages.pandas
        python3Packages.requests
        python3Packages.syncedlyrics
        python3Packages.pillow
        python3Packages.pygobject3
        playerctl
    # Do direct install
    # Add further lines to `installPhase` to install any extra data files if needed.
    dontUnpack = true;
    installPhase = ''
        install -Dm755 "${./${pname}}" "$out/bin/${pname}"
# default.nix
# cat default.nix
  nixpkgs = fetchTarball "https://github.com/NixOS/nixpkgs/tarball/nixos-24.05";
  pkgs = import nixpkgs {};
  waybar-media-player = pkgs.callPackage ./waybar-media-player.nix {};
this is what I have for my custom package, I haven’t tried changing any environment variables because I have no Idea where to even begin. I was doing research today but still haven’t come to a consensus of what to do.
hey again! im assuming this is the error you’re getting when trying to run the script:
# ./result/bin/waybar-mediaplayer-script
  File "/nix/store/7p2nrk1csx7rf4rxk0ygn8s9fg3rgz6d-waybar-mediaplayer-script-0.0.1/bin/.waybar-mediaplayer-script-wrapped", line 28, in <module>
  File "/nix/store/fr216icfk9iii3fw2yyfij4r3zddaa9s-python3.11-pygobject-3.48.2/lib/python3.11/site-packages/gi/__init__.py", line 122, in require_version
so playerctl is not in the gi namespace, so your program can’t find it. (dont do the following, it’s just to illustrate the problem) we could fix this by manually exposing the path through an environment variable:
    wrapProgram "$out/bin/${pname}" \
      --prefix GI_TYPELIB_PATH : "${pkgs.playerctl}/lib/girepository-1.0 \
      --prefix LD_LIBRARY_PATH : "${pkgs.playerctl}/lib
but then your program also depends on glib, so we’d have to do the same for that and any other dependencies. luckily, instead of manually enumerating these paths and modifying environment variables, we can use gobject-introspection combined with wrapGAppsHook to expose the gi libraries to the application.
doing this worked for me:
{ pkgs
, gobject-introspection
, wrapGAppsHook
pkgs.python3Packages.buildPythonApplication rec {
  version = "0.0.1";
  pyproject = false;
  src = ./.;
    playerctl
    glib
  nativeBuildInputs = [wrapGAppsHook gobject-introspection];
  dontUnpack = true;
  installPhase = ''
also gobject-introspection and wrapGAppsHook are provided by nixpkgs, but i’ve added them to the inputs because when you use callPackage ./file.nix {}; it will automatically pass them in when it sees that they’re required.
finally, running the app now also seems to error because it’s looking for a config file, you might want to either pass the location of the config file via a command line argument or include it in the package files with another install line in the installPhase
Thank you again for your help, sadly my laptop just borked itself (booting using grub gets me a grub terminal, and it’s been so long since I used the default nixOS boot menu that garbage collect took all of the generations it knows about) so I’ll have to test it once I reinstall and reconfigure my nixOS setup.
Only good news is that I experimented with backing up my system using GitHub a few weeks ago, though I’ve done a lot since then.
I’ll let you know if the fix works for me once I have everything set up again.
My system is back up & running!
yeah I need to add the config.json file somewhere.
judging from the python script (should have mentioned, I did not write this).
I need to place it in the same folder as the script itself, so I assume it would be best to add it via install, would the syntax be the same?
install -Dm755 "./config.json" "$out/bin/config.json"
or should it be different?
if you need any more context, this is the repository that this code comes from:https://github.com/raffaem/waybar-mediaplayer/tree/master
Edit
just tried it, it doesn’t work, but doing cp "./config.json" "$out/bin/config.json" did work.
ok, I have just realized that this is a much bigger project than I think I can handle.
but I’m going to try anyway, and I’m asking for advice.
there are three files that need to be in this package.
  1. the main script itself
  2. the config file for the script
  3. the secondary script that takes the config and creates a style.css file to be used by waybar.
I think the process (in terms of building the package) is something like this (pseudo code)
preInstallPhases() {
  install script-makeCSS out
  cp config.json out
installPhase() {
  run script-makeCSS
  install script-main out
is this correct?
the other issue I’m thinking of is that waybar then needs the path to the style.css file, how do I give it that? probably by moving it out of the store with postInstallPhase, but how do you do that? mv file $HOME/path/to/dir?
I know this has now reached beyond the scope of the original question, but I’m a noob and I’m very capable of biting off more than I can chew. sorry.
well, putting that part of the project on hold. turns out the build script actually wasn’t working. I for some reason thought it was, but it’s not.
I am getting the same error that this post was created for.
why? I have no idea, except that it’s related to session variables as mentioned above.
I did find this though: Cannot run reproducible PyGObject example script
and it seems to be the exact same problem but with a different program. the shell fix works (and I may just resign my self to using it) but the gobject-introspection solution does not work.
this goes into a much deeper rabbit-hole here: Python + Qt woes
and due to this, I’m just going to make a shell and live with the delay of starting the shell.
you can access it via the package eg
@import "/run/current-system/sw/share/waybar-mediaplayer-script/style.css";
