Hi,
I’ve recently moved to NixOS on my main computer after trying it on my server and come across a problem with my Rust + Bevy project. I use a flake to manage system dependencies and the rust toolchain as well as rust-analyzer. Using flake-compat I have a shell.nix that I can use with the nixEnvSelector code extension which seems to work fine.
rust-analyzer is erroring everywhere I use proc macros with error: “failed to build proc-macro”. There are a bunch of errors in the logs that look like this:
error: could not compile `syn` (lib) due to 2 previous errors
error: couldn't create a temp dir: No such file or directory (os error 2) at path "/tmp/nix-shell-34163-0/rustcGqyFCf"
error: aborting due to 1 previous error
Edit: This error also shows up: “proc-macro crate build data is missing dylib path”
Here’s my setup:
flake.nix
description = "Environment for developing bevy project";
# Flake inputs
flake-compat.url = "https://flakehub.com/f/edolstra/flake-compat/1.tar.gz";
# Flake outputs
outputs = { self, nixpkgs, ... }:
# Systems supported
allSystems = [
"x86_64-linux" # 64-bit Intel/AMD Linux
"aarch64-linux" # 64-bit ARM Linux
"x86_64-darwin" # 64-bit Intel macOS
"aarch64-darwin" # 64-bit ARM macOS
# Helper to provide system-specific attributes
forAllSystems = f: nixpkgs.lib.genAttrs allSystems (system: f {
pkgs = import nixpkgs {
inherit system;
# Development environment output
devShells = forAllSystems ({ pkgs }: {
default = pkgs.mkShell rec {
# The Nix packages provided in the environment
packages = with pkgs; [
rustc cargo rust-analyzer clippy rustfmt
pkg-config
udev alsa-lib vulkan-loader
libxkbcommon wayland # Wayland dependencies
xorg.libX11 xorg.libXcursor xorg.libXi xorg.libXrandr # X11 dependencies
LD_LIBRARY_PATH = "${nixpkgs.lib.makeLibraryPath packages}";
RUST_SRC_PATH = "${pkgs.rust.packages.stable.rustPlatform.rustLibSrc}";
.vscode/settings.json
“nixEnvSelector.nixFile”: “${workspaceFolder}/shell.nix”,
“editor.formatOnSave”: true,
“rust-analyzer.server.path”: “rust-analyzer”,
shell.nix (copied from flake-compat)
(import
lock = builtins.fromJSON (builtins.readFile ./flake.lock);
nodeName = lock.nodes.root.inputs.flake-compat;
fetchTarball {
url = lock.nodes.${nodeName}.locked.url or "https://github.com/edolstra/flake-compat/archive/${lock.nodes.${nodeName}.locked.rev}.tar.gz";
sha256 = lock.nodes.${nodeName}.locked.narHash;
{ src = ./.; }
).shellNix
Thanks!
