Rust code using bracket-lib library on wayland - problem
I am working through the excellent Hands On Rust book. This teaches rust programming through the medium of game development. The initial chapters use bracket-lib as a game engine. I am using my NixOS laptop for this task, which is running unstable plasma6, under wayland.
When I cargo run the simple example, I get the following errors:
Failed to initialize any backend! Wayland status: NoWaylandLib X11 status: LibraryOpenError(Op
enError { kind: Library, detail: “opening library failed (libX11.so.6: cannot open shared obje
ct file: No such file or directory); opening library failed (libX11.so: cannot open shared obj
ect file: No such file or directory)” })
I suspect I need to add something to my devshell flake, but I am not sure what is missing and would appreciate any tips!
The flake looks like this currently:
    rust-overlay = {
      url = "github:oxalica/rust-overlay";
        nixpkgs.follows = "nixpkgs";
        flake-utils.follows = "flake-utils";
  outputs = { self, nixpkgs, flake-utils, rust-overlay }:
    flake-utils.lib.eachDefaultSystem
      (system:
          overlays = [ (import rust-overlay) ];
          pkgs = import nixpkgs {
            inherit system overlays;
          rustToolchain = pkgs.pkgsBuildHost.rust-bin.fromRustupToolchainFile ./rust-toolchain.toml;
        with pkgs;
          devShells.default = mkShell {
            buildInputs = [
              rustToolchain
              cmake
              pkg-config
              fontconfig
Thanks for reading.
I’m experiencing the same issue…were you able to resolve this?
Hi @Tarzan9192 - In the end, I used X instead of Wayland. The problem is not Nix related - I put Gentoo back on my laptop, and recognised that the problem with Wayland is still there. Apologies for not replying when you posted last month.
