How to declaratively mount a samba share with a specific directory mode?
I would like to mount share that servers as nas for linux and windows machines. Samba share is on LAN.
I see that cifs mount does not support setting dmask/umask and changing directory mode manually via chmod
does not work either, it remains 755
for some reason
I use following configuration for mounting:
fileSystems."/run/media/nas" = {
device = "//192.168.0.99/nas";
fsType = "cifs";
options = [
"credentials=${config.sops.templates."samba-nas".path}"
"x-systemd.automount"
"noauto"
"x-systemd.idle-timeout=60"
"x-systemd.device-timeout=5s"
"x-systemd.mount-timeout=5s"
"rw"
"uid=${builtins.toString config.users.users.myuser.uid}"
"gid=${builtins.toString config.users.groups.users.gid}"
Recommendation on SO thread is to either use subdirectories or pam_mount. First does not help since the target mount is still 755
while I want group members to have write access. The other adds the whole new service that is only used to permorm seemingly trivial operation(same with gvfs)
