how can i change the variant for this sddm theme? GitHub - Keyitdev/sddm-astronaut-theme: Series of modern looking themes for SDDM. · GitHub it says
Selecting a theme
You can select theme by editing metadata (/usr/share/sddm/themes/sddm-astronaut-theme/metadata.desktop).
Just edit this line:
ConfigFile=Themes/astronaut.conf
how do i do that? i have tried this thing i found from github searching but didn’t work
sddm-sugar-dark
(sddm-astronaut.override
themeConfig = {
theme = "black_hole";
My entire file for sddm is simply
lib,
pkgs,
config,
}: let
cfg = config.custom.sddm;
sddm-astronaut = pkgs.sddm-astronaut.override {
embeddedTheme = "astronaut";
# embeddedTheme = "black_hole";
# embeddedTheme = "cyberpunk";
options.custom.sddm = {
enable = lib.mkEnableOption "Enable sddm display";
config = lib.mkIf cfg.enable {
sddm-astronaut
services.displayManager.sddm = {
theme = "sddm-astronaut";
wayland.enable = true;
extraPackages = [ sddm-astronaut ];
So the astronaut theme is already packaged in the nixpkgs:
So with that you can just use it as following:
theme = "sddm-astronaut-theme";
settings = {
Theme = {
CursorTheme = config.stylix.cursor.name;
CursorSize = config.stylix.cursor.size;
extraPackages = with pkgs; [
kdePackages.qtsvg
kdePackages.qtvirtualkeyboard
kdePackages.qtmultimedia
(sddm-astronaut.override {
themeConfig = {
ScreenWidth = "1920";
ScreenHeight = "1080";
Font = config.stylix.fonts.sansSerif.name;
FontSize = "12";
RoundCorners = "20";
BackgroundPlaceholder = "${config.stylix.image}";
Background =
if cfg.animatedBackground.enable
then "${cfg.animatedBackground.path}"
else "${config.stylix.image}";
BackgroundSpeed = "1.0";
PauseBackground = "";
CropBackground = "false";
BackgroundHorizontalAlignment = "center";
BackgroundVerticalAlignment = "center";
DimBackground = "0.0";
HeaderTextColor = "${text}";
DateTextColor = "${text}";
TimeTextColor = "${text}";
FormBackgroundColor = "${base}";
DimBackgroundColor = "${base}";
LoginFieldBackgroundColor = "#${base}";
PasswordFieldBackgroundColor = "${base}";
LoginFieldTextColo = "${mauve}";
PasswordFieldTestColor = "${mauve}";
UserIconColor = "${mauve}";
PasswordIconColor = "${mauve}";
PlaceholderTextColor = "${surface2}";
WarningColor = "${red}";
LoginButtonTextColor = "${mauve}";
LoginButtonBackgroundColor = "${base}";
SystemButtonsIconsColor = "${mauve}";
SessionButtonTextColor = "${mauve}";
VirtualKeyboardButtonTextColor = "${mauve}";
DropdownTextColor = "${mauve}";
DropdownSelectedBackgroundColor = "${base}";
DropdownBackgroundColor = "${base}";
HighlightTextColor = "${mauve}";
HighlightBackgroundColor = "${mauve}";
HighlightBorderColor = "${mauve}";
HoverUserIconColor = "${teal}";
HoverPasswordIconColor = "${teal}";
HoverSystemButtonsIconsColor = "${teal}";
HoverSessionButtonTextColor = "${teal}";
HoverVirtualKeyboardButtonTextColor = "${teal}";
PartialBlur = "true";
BlurMax = "35";
Blur = "2.0";
HaveFormBackground = "false";
FormPosition = "left";
Source
Reddit - The heart of the internet
With the override you can then configure the theme
I don’t have stylix set up yet. I just want to change the “variant” of the theme. is this enough for that?
because even with that it is not working. if i leave that out, however, i get the astronaut variant
you can just leave the stylix option out.
That is most likely because the astronaut version is the default. Maybe try the override in the extra packages in the sddm config:
sddm = {
package = pkgs.kdePackages.sddm;
extraPackages = [(pkgs.sddm-astronaut.override {
embeddedTheme = "your_theme";
That also seems to not work. There is only the default theme.
ok that is strange. Have you removed all other mentions of the sddm-astronaut package?
It should only be specified in the sddm.extraPackages with the override. Also it is important that you use:
To give sddm the correct folder for the theme.
From the NixOS Options it looks like you have to pass the path to the directory:
services.displayManager.sddm.theme = "${pkgs.sddm-astronaut.override { embeddedTheme = "black-hole"; }}/share/sddm/themes/sddm-astronaut-theme"
This would be my guess, I haven’t tested.
This one completely broke the theme, white background, nothing visible except the black characters “password” and “username”.
what broke the theme completley.
leoperegrino:
This? or this?
Postboote:
Sorry, i thought hitting reply was enough. I am not sure how to cite stuff but this line
the other one just resulted in the default sddm theme again
I found out i need to package it myself apparently. and then use callPackage. This is complicated but i guess i have my answer
I found a solution somebody else used that worked:
D99
May 23, 2026, 3:50am
13
i found a different solution, hopefully it’s useful for anyone else.
include sddm-astronaut package on systemPackages and if you want the default astronaut config you can leave it like this
sddm-astronaut
sddm-astronaut
use sudo nixos-rebuild test and then check the available options
ls -1 /run/current-system/sw/share/sddm/themes/sddm-astronaut-theme/Themes/*.conf
use the filename of the option that you want on the sddm config block (example: black_hole)
theme = "${pkgs.sddm-astronaut.override { embeddedTheme = "black_hole"; }}/share/sddm/themes/sddm-astronaut-theme";
extraPackages = [
(pkgs.sddm-astronaut.override { embeddedTheme = "black_hole"; })
finally restart the display manager
sudo systemctl restart display-manager
