Bilkin
July 21, 2024, 5:34pm
1
I’m trying to configure Zellij using KDL. I believe there exists a nix-to-kdl parser. However, I’m struggling to generate certain KDL constructs using nix.
Where can I obtain documentation for the KDL format conversion in NixOS? Is there a general repository containing conversion details for nix-to-toml, nix-to-yaml and other formats? I’m getting a little tired of just poking around, hoping something works.
Thank you!
NOTE: I originally posted this on reddit, but it appears to have been lost in other discussion. I will repost any working solutions there.
nix-to-{to,ya}ml is available in Nixpkgs:
https://noogle.dev/f/pkgs/writers/writeTOML
https://noogle.dev/f/pkgs/writers/writeYAML
However I never heard of KDL as a format used in Nixpkgs. Indeed it would be a nice addition to Nixpkgs!
To add a cross-reference, there is an open discussion of supporting the KDL format over on github.
GH issues don’t really go anywhere, they’re just for tracking purposes. However there was a PR created that stalled a few months ago:
NixOS:master ← feathecutie:formats-kdl
opened 03:04AM - 12 Mar 24 UTC
## Description of changes
For package updates please link to a changelo… g or describe changes, this helps your fellow maintainers discover breaking updates.
Adds `pkgs.formats.kdl`, a Nix representation of the [KDL document language](https://kdl.dev/) using the standard `pkgs.formats` format.
Also inits `json2kdl`, a custom-built application which is required for the core functionality of `pkgs.formats.kdl`.
Closes #198655.
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
Thanks a lot if you do!
