When I open multiple instances of emacs in nixos (with gnome desktop manager)
I found like below
I want each instance of emacs is shown in seperate way. Can I do that?
I found like below
By default, Super-Tab and Alt-Tab keyboard shortcuts switch applications rather than windows in GNOME Shell.
You can change the behaviour to something that more closely matches the behaviour of other window managers:
Or, alternately, run the following commands:
dconf write "/org/gnome/desktop/wm/keybindings/switch-applications" "@as []"
dconf write "/org/gnome/desktop/wm/keybindings/switch-applications-backward" "@as []"
dconf write "/org/gnome/desktop/wm/keybindings/switch-windows" "['<Super>Tab', '<Alt>Tab']"
dconf write "/org/gnome/desktop/wm/keybindings/switch-windows-backward" "['<Shift><Super>Tab', '<Shift><Alt>Tab']"
See GSettings section of NixOS manual, if you want to configure it declaratively. (Or home-manager example.)
