What is the correct way of setting buildPhase environment variables?
The gory details
It works in a nix-shell
I have a shell.nix which I used to provide dependencies while hacking on some Rust code. It contains (among much other noise)
pkgs.stdenv.mkDerivation {
buildInputs = [
pkgs.hdf5
pkgs.clang_11
LD_LIBRARY_PATH = "${pkgs.stdenv.lib.makeLibraryPath buildInputs}";
HDF5_DIR = pkgs.symlinkJoin { name = "hdf5"; paths = [ pkgs.hdf5 pkgs.hdf5.dev ]; };
# Needed if using bindgen to wrap C libraries in Rust
LIBCLANG_PATH = "${pkgs.llvmPackages_11.libclang}/lib";
This allowed me to run a nix-shell in which I successfully compiled the code by hand with cargo, giving me executables which successfully used HDF5 and the bindgen-generated bindings at runtime.
It works in nix develop
I am trying to transition this to a flake.
By specifying the above environment variables inside devShell = pkgs.mkShell rec { ... }, in exactly the same way as above, I can successfully compile and run with cargo build/run inside a nix develop shell.
I can’t get the flake to build successfully
nix build and friends fail with errors like
builder for '/nix/store/nxpqj6kllc5c1nmzk6ipk1idj0frxk36-hmm.drv' failed with exit code 101; last 10 log lines:
configuring
building
error: failed to get `hdf5` as a dependency of package `hmm v0.1.0 (/build/source)`
Caused by:
failed to create directory `/homeless-shelter/.cargo/registry/index/github.com-1ecc6299db9ec823`
Caused by:
Permission denied (os error 13)
where the buildPhase is set to cargo build --release.
Advice?
What is the best way to make these environment variables available during buildPhase?
How can I minimize code duplication between package.whatever and devShell, when setting these variables?
It leaves me with a copypasta of the lines setting those variables, between my package and my devShell. Can that be mitigated?
It now fails, persistently, with
builder for '/nix/store/fvs7vi7ypk3m5ii7k2fw729q0rh50k0g-hmm.drv' failed with exit code 101; last 10 log lines:
Caused by:
failed to fetch `https://github.com/rust-lang/crates.io-index`
Caused by:
network failure seems to have happened
if a proxy or similar is necessary `net.git-fetch-with-cli` may help here
https://doc.rust-lang.org/cargo/reference/config.html#netgit-fetch-with-cli
Caused by:
failed to resolve address for github.com: Name or service not known; class=Net (12)
Pinging github.com succeeeds.
wgeting the URL which failed to fetch also works.
I’ve been watching the builds fetch craties.io-index all day.
You can probably just use your package as devShell, potentially using overrideAttrs if you need to change something for the devShell.
As for the network failure, Nix builds are running in a sandbox without network access (this has been the case long before flakes). You will need to use rustPlatform.buildRustPackage or naersk.
I had naersk set aside in my too-much-magic-for-now box, but after seeing how much hassle it is to get rustPlatform to use a non-prehistoric version of the rust toolchain, I decided to give naersk a go.
I was trying to use the stable 1.50.0 channel of rustOverlay, which errored with
error: the `--out-dir` flag is unstable, and only available on the nightly channel of Cargo, but this is the `stable` channel
while the naersk docs state that
Note: naersk relies on the --out-dir out option
So, would it be correct to conclude that naersk simply can’t be used with a stable rustOverlay?
