I have a set of packages for which I need to apply specific compilation and linking flags. How can I apply these flags to a set of packages so that I do not have to:
stdenv.mkDerivation {
env.NIX_CFLAGS_COMPILE = "-someflag";
for each package? The answer seems to be to use an overlay on nixpkgs, but documentation is scarce and examples even more so. I have tried the following overlays:
myOverlay = self: super: {
stdenv = super.stdenvAdapters.addAttrsToDerivation {
} super.stdenv;
returns the error: The ‘env’ attribute set cannot contain any attributes passed to derivation. The following attributes are overlapping: NIX_CFLAGS_COMPILE.
stdenv = super.stdenv.overrideDerivation (oldAttrs: {
env.NIX_CFLAGS_COMPILE = oldAttrs.env.NIX_CFLAGS_COMPILE + " -someflag";
returns the error: attribute ‘targetPlatform’ missing. So it seems like I have overridden more than just NIX_CFLAGS_COMPILE
in this case.
stdenv = super.withCFlags ["-someflag"] super.stdenv;
works, but now I have no way to set linker flags. I also tried config.replaceStdenv
as follows:
pkgs = import sources.nixpkgs {
config.replaceStdenv = {pkgs}: pkgs.withCFlags ["-someflag"] pkgs.stdenv;
# overlays = [
# myOverlay
which I would expect to have the same effect as the previous attempt however, during building GNU hello, this crashes with configure: error: C compiler cannot create executables.
I am quite lost on how to proceed at this point and feel like I am basically just guessing my way to a solution.
