Trying to set up an equivalent to git maintenance register
on NixOS (since running that imperative command literally would generate a service file with hardcoded paths, thereby breaking on every time those paths are invalidated).
This is my attempt, adapted from the service file that git
itself would generate:
(Ignore the details of mapListToAttrs
, it should be unrelated to the issue at hand.)
systemd.user = {
services."git-maintenance@" = {
description = "Optimize Git repositories data";
serviceConfig = {
ExecStart = ''"${getExe config.programs.git.package}" --exec-path="${getBin config.programs.git.package}/bin" for-each-repo --keep-going --config=maintenance.repo maintenance run --schedule=%i'';
timers =
mapListToAttrs (OnCalendar: "git-maintenance@${OnCalendar}")
(OnCalendar: {
timerConfig = {
inherit OnCalendar;
Persistent = true;
"hourly"
"daily"
"weekly"
And I have, in my ~/.config/git/config
[maintenance]
repo = "/path/to/repo1"
repo = "/path/to/repo2"
strategy = "incremental"
However, when I attempt to run (or let the system automatically run) one of the services, e.g. git-maintenance@hourly
$ systemctl --user status git-maintenance@hourly
× git-maintenance@hourly.service - Optimize Git repositories data
Loaded: loaded (/etc/systemd/user/git-maintenance@.service; static)
Active: failed (Result: exit-code) since TIMESTAMP; 1s ago
Duration: 882ms
Invocation: ff155269ee424b5a85c69490c8dea89e
TriggeredBy: ● git-maintenance@hourly.timer
Process: 784921 ExecStart=/nix/store/pxpns5vm111i6j3r3wbygaj99wbrm6h1-git-2.47.0/bin/git for-each-repo --keep-going --config=maintenance.repo maintenance run --schedule=hourly (code=exited, status=1/FAILURE)
Main PID: 784921 (code=exited, status=1/FAILURE)
Mem peak: 7.2M
CPU: 100ms
TIMESTAMP HOST systemd[1731]: Started Optimize Git repositories data.
TIMESTAMP HOST git[784929]: error: failed to prefetch remotes
TIMESTAMP HOST git[784929]: error: task 'prefetch' failed
TIMESTAMP HOST systemd[1731]: git-maintenance@hourly.service: Main process exited, code=exited, status=1/FAILURE
TIMESTAMP HOST systemd[1731]: git-maintenance@hourly.service: Failed with result 'exit-code'.
Meanwhile running the command manually works fine:
$ git for-each-repo --keep-going --config=maintenance.repo maintenance run --schedule=hourly
$ echo $?
0
How do I get this command to work correctly in a systemd service?
