How can I then append/prepend the following elements to my PATH env var:
${NPM_CONFIG_PREFIX}/bin
${$PNPM_HOME}/bin
${CARGO_HOME}/bin
I am currently using environment.shellInit and programs.fish.shellInit and duplicate the PATH construction logic, but I was wondering if there is a way to avoid doing that.
You probably want to add $CARGO_HOME/bin to your PATH because you use(d) cargo install to install software. This software will eventually break (dynamic linker) and you need to reinstall it.
To solve that, you instead package this software and add it to your environment.systemPackages/users.users.<name>.packages/home.packages, depending on your preferences.
What the others are telling you is correct… however, if you aren’t going to take their advice, path-manipulating logic should go in environment.extraInit, not shellInit.
