Hi,
I’m trying to understand how to set up vscode docker extension (ms-azuretools.vscode-docker) to use podman socket on nixos using home manager.
systemctl status podman.socket → active (listening)
socat -u -ddd OPEN:/dev/null UNIX-Connect:/run/podman/podman.sock → “successfully connected from local address”
If I’m not wrong, I should set up:
# VScodium
programs.vscode = {
package = pkgs.vscodium;
extensions = with pkgs.vscode-extensions; [
userSettings = {
# Podman settings for Docker extension (modified host path)
"docker.dockerPath" = "podman";
"docker.environment" = { "DOCKER_HOST" = "unix:///run/podman/podman.sock"; } ;
I can see DOCKER_HOST is properly set in UI but it still won’t work. Any help will be appreciated
