Hello,
I’ve made this shell.nix
that allows for me to reliably build the packages and follow along with the book using cabal
# shell.nix
{ nixpkgs ? import (builtins.fetchTarball {
url = "https://github.com/NixOS/nixpkgs/archive/5c79b3dda06744a55869cae2cba6873fbbd64394.tar.gz";
# Pins to a version of nixpkgs where ghc 8.8.4 was the main ghc (I think)
# gotten from https://lazamar.co.uk/nix-versions/?package=ghc&version=8.8.4&fullName=ghc-8.8.4&keyName=ghc&revision=5c79b3dda06744a55869cae2cba6873fbbd64394&channel=nixpkgs-unstable#instructions
hpkgs = nixpkgs.haskell.packages."ghc884";
hpkgs.shellFor {
name = "parconc-examples";
packages = _: [];
buildInputs = with hpkgs; [
cabal-install
haskell-language-server
nixpkgs.pkg-config # Needed to build some packages
nixpkgs.zlib # Needed to build some packages
implicit-hie
- Enter the environment with
nix-shell
. - Update cabal with
cabal update
. - Build the executable(s) with
cabal build [package]
- Run the executable with
cabal run
. So for example:
$ ghc -O2 rpar.hs -threaded
$ ./rpar 1 + RTS -N2
becomes
$ cabal build rpar
$ cabal run rpar 1 -- +RTS -N2
EDIT: Got HLS working.
Added implicit-hie
to buildInputs
OPTIONAL: To work with HLS, in the nix-shell
, run gen-hie > hie.yaml
