SOF SoundWire audio configuration
Hello everyone, I have been using NixOS for a few weeks and for several days I have been struggling to find a working and persistent audio configuration. My PC is a Dell Pro Max 14 (MC14250). I haven’t found anything relevant in the nixos-hardware repository or on the web.
My goals are:
  • to have all audio profiles working (“Pro Audio” and “Stereo Output”), i.e., the internal speakers and microphone.
  • to have Bluetooth headphones (with microphone) working. I am using Sony LinkBuds S, which should support these codecs: SBC, AAC, LDAC, and LC3.
Currently, the “Pro Audio” profile is the only one that works; it is activated automatically at startup. No sound is reproduced when the “Stereo Output” profile is active. When the headphones are connected, I have the HSP/HFP profiles with CVSD and mSBC codecs available, but no sound is reproduced.
Unfortunately, I don’t know much about audio in Linux, and my configuration is the result of various trials and errors (I’m sorry if it is messy):
{ config, pkgs, inputs, ... }:
  imports = [
    ./hardware-configuration.nix
  networking.hostName = "pc";
  ## Dell Pro Max 14 Audio Configuration ##
  hardware.enableAllFirmware = true;
  hardware.enableRedistributableFirmware = true;
  hardware.firmware = with pkgs; [
    sof-firmware
    linux-firmware
  boot.kernelParams = [
    "snd-intel-dspcfg.dsp_driver=3"
    "intel_iommu=on"
    "iommu=pt"
  boot.extraModprobeConfig = ''
    options snd-intel-dspcfg dsp_driver=3
  security.rtkit.enable = true;
  services.pipewire = {
    alsa.enable = true;
    alsa.support32Bit = true;
    pulse.enable = true;
    wireplumber.enable = true;
    extraConfig.pipewire-pulse = {
      "pulse.properties" = {
        "flat-volumes" = false;
    # WirePlumber config
    wireplumber.extraConfig = {
      "51-dell-routing" = {
        "monitor.alsa.rules" = [
            matches = [ { "node.name" = "alsa_output.pci-0000_00_1f.3-platform-sof_sdw.pro-output-2"; } ];
            actions = { "update-props" = {
              "priority.session" = 3000;
              "node.autoconnect" = true;
              "node.nick" = "Internal Speakers";
            matches = [ { "node.name" = "alsa_input.pci-0000_00_1f.3-platform-sof_sdw.pro-input-4"; } ];
              "node.nick" = "Internal Mic";
          # disable HDMI (5/6/7) and the ones you don’t use (0/31), so policy/UI can’t jump to them
            matches = [
              { "node.name" = "alsa_output.pci-0000_00_1f.3-platform-sof_sdw.pro-output-5"; }
              { "node.name" = "alsa_output.pci-0000_00_1f.3-platform-sof_sdw.pro-output-6"; }
              { "node.name" = "alsa_output.pci-0000_00_1f.3-platform-sof_sdw.pro-output-7"; }
              { "node.name" = "alsa_output.pci-0000_00_1f.3-platform-sof_sdw.pro-output-0"; }
              { "node.name" = "alsa_output.pci-0000_00_1f.3-platform-sof_sdw.pro-output-31"; }
              "node.disabled" = true;
              "priority.session" = 1;
  # Init service
  systemd.services.dell-audio-init = {
    description = "Initialize Dell audio";
    after = [ "sound.target" ];
    wantedBy = [ "sound.target" ];
    serviceConfig = {
      Type = "oneshot";
      RemainAfterExit = true;
      ExecStartPre = "${pkgs.coreutils}/bin/sleep 10";
    script = ''
      # Speaker path
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset name='rt1320-1 OT23 L Switch' on || true
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset name='rt1320-1 OT23 R Switch' on || true
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset name='Speaker Switch' on || true
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset name='Pre Mixer Speaker Playback Volume' 45,45 || true
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset name='Post Mixer Speaker Playback Volume' 45,45 || true
      # Mic path
      # Route both ADCs to DMIC1 (works fine on your hardware)
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset name='rt722 ADC 24 Mux' 0 || true
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset name='rt722 ADC 25 Mux' 0 || true
      # Set capture switches
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset numid=2 on,on || true    # FU0F Capture Switch
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset numid=6 on,on,on,on || true  # FU1E Capture Switch
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset numid=11 on,on,on,on || true # rt1320 Capture Switch
      # Set capture volumes
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset numid=3 30,30 || true        # FU0F Capture Volume
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset numid=7 30,30,30,30 || true  # FU1E Capture Volume
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset name='rt722 FU15 Boost Volume' 3,3,3,3 || true
      ${pkgs.alsa-utils}/bin/amixer -c 0 cset name='rt722 FU33 Boost Volume' 2,2 || true
      # Save ALSA state
      ${pkgs.alsa-utils}/bin/alsactl store 0 || true
  systemd.user.services."audio-defaults" = {
    description = "Set default sink/source and volume";
    after = [ "pipewire-pulse.service" "wireplumber.service" ];
    wantedBy = [ "default.target" ];
    script = ''
      ${pkgs.pipewire}/bin/wpctl set-default alsa_output.pci-0000_00_1f.3-platform-sof_sdw.pro-output-2 || true
      ${pkgs.pipewire}/bin/wpctl set-default alsa_input.pci-0000_00_1f.3-platform-sof_sdw.pro-input-4 || true
      ${pkgs.pipewire}/bin/wpctl set-mute @DEFAULT_AUDIO_SINK@ 0 || true
      ${pkgs.pipewire}/bin/wpctl set-volume @DEFAULT_AUDIO_SINK@ 1.0 || true
  # Restore ALSA state on boot
  hardware.alsa.enablePersistence = true;
  ## Networking, BT ##
  networking.networkmanager.wifi.backend = "iwd";
  hardware.bluetooth = {
    powerOnBoot = true;
    settings = {
      General = {
        Enable = "Source,Sink,Media,Socket";
        Experimental = true;
  services.blueman.enable = true;
  services.pipewire.wireplumber.extraConfig."60-bluetooth" = {
    "monitor.bluez.properties" = {
      "bluez5.enable-sbc-xq" = true;
      "bluez5.enable-msbc" = true;
      "bluez5.enable-hw-volume" = true;
      "bluez5.roles" = [ "hsp_hs" "hsp_ag" "hfp_hf" "hfp_ag" ];
  system.stateVersion = "25.05";
Here are some debug commands that I think might be useful:
nixos-version --json
{"nixosVersion":"25.05.20250917.e9b7f2f","nixpkgsRevision":"e9b7f2ff62b35f711568b1f0866243c7c302028d"}
uname -r
6.16.7
nix --version
nix (Nix) 2.28.5
wpctl status when Pro-Audio is active:
wpctl status
PipeWire 'pipewire-0' [1.4.7, marco@pc, cookie:916607124]
 └─ Clients:
        34. WirePlumber                         [1.4.7, marco@pc, pid:1815]
        35. pipewire                            [1.4.7, marco@pc, pid:1814]
        48. WirePlumber [export]                [1.4.7, marco@pc, pid:1815]
        49. .xdg-desktop-portal-wrapped         [1.4.7, marco@pc, pid:1768]
        50. .xdg-desktop-portal-hyprland-wrapped [1.4.7, marco@pc, pid:1840]
        51. waybar                              [1.4.7, marco@pc, pid:1725]
        52. Blueman                             [1.4.7, marco@pc, pid:1731]
        66. .pwvucontrol-wrapped                [1.4.7, marco@pc, pid:11617]
        76. Firefox                             [1.4.7, marco@pc, pid:1992]
        77. .pwvucontrol-wrapped                [1.4.7, marco@pc, pid:11617]
        83. .pwvucontrol-wrapped                [1.4.7, marco@pc, pid:11617]
        93. wpctl                               [1.4.7, marco@pc, pid:34004]
        94. Blueman                             [1.4.7, marco@pc, pid:16344]
Audio
 ├─ Devices:
 │      53. sof-soundwire                       [alsa]
 ├─ Sinks:
 │  *   68. sof-soundwire Pro 2                 [vol: 0.65]
 ├─ Sources:
 │      69. sof-soundwire Pro 1                 [vol: 1.00]
 │  *   70. sof-soundwire Pro 4                 [vol: 1.00]
 ├─ Filters:
 └─ Streams:
       102. PulseAudio Volume Control
             84. input_FL        < Internal Mic:capture_AUX0	[active]
             85. input_FR        < Internal Mic:capture_AUX1	[active]
             97. monitor_FL
            110. monitor_FR
       105. PulseAudio Volume Control
             80. monitor_FL
             98. input_FR        < Pro 1:capture_AUX1	[active]
            101. input_FL        < Pro 1:capture_AUX0	[active]
            109. monitor_FR
Video
 ├─ Devices:
 │      57. Integrated_Webcam_FHD               [v4l2]
 │      58. Integrated_Webcam_FHD               [v4l2]
 │      59. Integrated_Webcam_FHD               [v4l2]
 │      60. Integrated_Webcam_FHD               [v4l2]
 │      64. Integrated_Webcam_FHD: Integrat     [libcamera]
 │      65. Integrated_Webcam_FHD: Integrat     [libcamera]
 ├─ Sinks:
 ├─ Sources:
 │  *   72. Integrated_Webcam_FHD (V4L2)
 │      74. Integrated_Webcam_FHD (V4L2)
 ├─ Filters:
 └─ Streams:
Settings
 └─ Default Configured Devices:
         0. Audio/Sink    alsa_output.pci-0000_00_1f.3-platform-sof_sdw.pro-output-2
         1. Audio/Source  alsa_input.pci-0000_00_1f.3-platform-sof_sdw.pro-input-4
wpctl status when Stereo Output is active:
 wpctl status
 └─ Clients:
        46. .pwvucontrol-wrapped                [1.4.7, marco@pc, pid:11617]
        87. wpctl                               [1.4.7, marco@pc, pid:35435]
Audio
 ├─ Devices:
 ├─ Sinks:
 │  *   70. sof-soundwire Stereo                [vol: 1.20]
 ├─ Sources:
 ├─ Filters:
 └─ Streams:
        68. PulseAudio Volume Control
             44. monitor_FL
             67. monitor_FR
             71. input_FR        < Stereo:monitor_FR	[active]
             78. input_FL        < Stereo:monitor_FL	[active]
Video
 ├─ Devices:
 ├─ Sinks:
 ├─ Sources:
 ├─ Filters:
 └─ Streams:
Settings
wpctl status when headphones are connected and selected:
wpctl status
 └─ Clients:
        46. .pwvucontrol-wrapped                [1.4.7, marco@pc, pid:37964]
        68. wpctl                               [1.4.7, marco@pc, pid:41853]
Audio
 ├─ Devices:
 │      67. LinkBuds S                          [bluez5]
 ├─ Sinks:
 │  *  102. LinkBuds S                          [vol: 1.00]
 ├─ Sources:
 │  *   71. LinkBuds S                          [vol: 1.00]
 ├─ Filters:
 └─ Streams:
        69. Firefox
             44. output_MONO     > LinkBuds S:playback_MONO	[init]
Video
 ├─ Devices:
 ├─ Sinks:
 ├─ Sources:
 ├─ Filters:
 └─ Streams:
Settings
Thanks in advance for any help. (This is my first post, so I apologize if I’ve made any mistakes or left anything out).
Interesting enough, I have the same issues on a Dell 14 pro, and sound used to work for me – about a week ago. Im on Ubuntu 25.10, though. I’m wondering if we somehow got a bad firmware update :frowning:
It was shipped with Ubuntu 24.04 LTS: speakers, mic and webcam worked out of the box. Since the plan was to use NixOS I installed it the same day without testing Bluetooth. A couple of weeks later I tried Ubuntu 25.04 in a live ISO USB, to verify exactly what you are saying but surprisingly everything worked (still didn’t test Bluetooth). Hope someone has suggestions.
On my system Im seeing a SOF-Firmware upgrade:
2025-09-19 16:19:49 status installed firmware-sof-signed:all 2025.01-1ubuntu1~25.04.2
2025-09-25 09:09:42 status installed firmware-sof-signed:all 2025.01-1ubuntu1~25.04.3
2025-10-14 23:42:27 status installed firmware-sof-signed:all 2025.05.1-1
Maybe I can roll back the one from the 14th
It would be really helpful even for me. If someone has any clue, please tell us!!!
Wait, I think that is the package version; the actual firmware blob version loaded by the driver may or may not exactly match the package version. From what I understand your sof version should be 2.13.1. I dont know if this is useful for my hardware; to try it I should use the unstable NixOS branch.
Also I see a BIOS update on DELL website on 14th October 2025 for “Dell Pro Max 14 MC14250/16 MC16250” maybe it’s a coincidnce idk.
It would be nice to know your BIOS version and SOF version to understand if we actually have the same problem. I am going to perform all the updates later today and then I’m gonna try the unstable channel with updated SOF.
For now this is my pc status:
sof version ( 2.12.0.1):
sudo dmesg | grep -E "sof.*firmware|sof.*version"
[    7.313895] sof-audio-pci-intel-mtl 0000:00:1f.3: Loaded firmware library: ADSPFW, version: 2.12.0.1
[    7.442028] sof-audio-pci-intel-mtl 0000:00:1f.3: Booted firmware version: 2.12.0.1
current BIOS (1.7.0):
sudo dmidecode -t bios
# dmidecode 3.6
Getting SMBIOS data from sysfs.
SMBIOS 3.8 present.
# SMBIOS implementations newer than version 3.7.0 are not
# fully supported by this version of dmidecode.
Handle 0x0000, DMI type 0, 26 bytes
BIOS Information
	Vendor: Dell Inc.
	Version: 1.7.0
	Release Date: 08/14/2025
	ROM Size: 64 MB
	Characteristics:
		PCI is supported
		PNP is supported
		BIOS is upgradeable
		BIOS shadowing is allowed
		Boot from CD is supported
		Selectable boot is supported
		EDD is supported
		Print screen service is supported (int 5h)
		8042 keyboard services are supported (int 9h)
		Serial services are supported (int 14h)
		Printer services are supported (int 17h)
		ACPI is supported
		USB legacy is supported
		Smart battery is supported
		BIOS boot specification is supported
		Function key-initiated network boot is supported
		Targeted content distribution is supported
		UEFI is supported
	BIOS Revision: 1.7
	Firmware Revision: 1.19
Handle 0x0D00, DMI type 13, 22 bytes
BIOS Language Information
	Language Description Format: Abbreviated
	Installable Languages: 1
		enUS
	Currently Installed Language: enUS
EDIT: After the BIOS update I can “use” Bluetooth headset. But let’s break it down:
  • checked for updates with: fwupdmgr get-updates and then update via: sudo fwupdmgr update.
  • tested speaker with Pro Audio, they still working fine.
  • tested speakers with Stereo Output and of course nothing changed, they simply don’t work.
  • connected my Sony LinkBuds S, selected them as Firefox audio and they work with both HSP/HFP codec mSBC and codec CVSD. With those two profiles the audio is actually terrible, in the next few days, I will try different things.
Even if I do not fully understand how this update can have something to do with Bluetooth or audio in general. I want to emphasize that I haven’t changed anything in my configuration before or after this process.
I will post updates here.
[    4.138577] sof-audio-pci-intel-mtl 0000:00:1f.3: Loaded firmware library: ADSPFW, version: 2.13.0.1
[    4.264969] sof-audio-pci-intel-mtl 0000:00:1f.3: Booted firmware version: 2.13.0.1
and
# dmidecode 3.6
SMBIOS 3.8 present.
Handle 0x0001, DMI type 0, 26 bytes
BIOS Information
	Vendor: Dell Inc.
	Version: 2.6.1
	Release Date: 08/26/2025
	ROM Size: 64 MB
	Characteristics:
		PCI is supported
		PNP is supported
		BIOS is upgradeable
		EDD is supported
		ACPI is supported
		UEFI is supported
	BIOS Revision: 2.6
	Firmware Revision: 1.16
		enUS
and still not working, will investigate BIOS Update…
Any update here? I’m deciding which Linux distro to put on a Dell Pro Max 14.
