[Solved] Difference between `imports` and `require`
Let’s say I have the following ~/.config/home-manager/home.nix:
{ config, pkgs, ... }:
  imports = [
    ./helix.nix
If I change the attribute imports into require, home manager would still build my config. So it seems like they are doing the same thing. Is there any thing I should be wary of that could break my config when I use require instead?
I don’t remember require to be a thing… I’ve looked into the nixpkgs, home-manager, and even nix builtins documentation, but couldn’t find it. Could you please share where you saw it used?
Maybe it builds it, but ignores the values you provide:
In the end, you return an attrset that has an array of path as values for a require key;
It’s likely that home-manager doesn’t know what to do with it, but doesn’t fail.
For example, you could have
  foo = "bar";
and still expect your configuration to build properly.
require is really old syntax IIRC - you probably shouldn’t use it anymore
it is part of the module system so it would work in a number of places, including home-manager
I remember I wanted to create an option require for nix2vim project and ran into an issue. I wonder why we don’t remove it? Probably, at this point even deprecation notice is not needed
Yeah, require is ignored entirely:
Probably it was just forgotten about?
