Steps to reproduce:
- Install the latest .Net sdk on NixOS
dotnet new -i JaggerJo.Avalonia.FuncUI.Templates
dotnet new avalonia-funcUI-basic -n NewApp
cd NewApp
then:
$ # runs fine
$ dotnet build
$ # breaks
$ dotnet run
Unhandled Exception: System.DllNotFoundException: Unable to load shared library 'libX11.so.6' or one of its dependencies. In order to help diagnose loading problems, consider setting the LD_DEBUG environment variable: liblibX11.so.6.so: cannot open shared object file: No such file or directory
at Avalonia.X11.XLib.XInitThreads()
at Avalonia.X11.AvaloniaX11Platform.Initialize(X11PlatformOptions options) in D:\a\1\s\src\Avalonia.X11\X11Platform.cs:line 31
at Avalonia.Controls.AppBuilderBase`1.Setup() in D:\a\1\s\src\Avalonia.Controls\AppBuilderBase.cs:line 302
at Avalonia.Controls.AppBuilderBase`1.Start(AppMainDelegate main, String[] args) in D:\a\1\s\src\Avalonia.Controls\AppBuilderBase.cs:line 153
at App.Program.Main(String[] args) in /home/usul/Github/Horatius/src/App/Main.fs:line 56
Also, this seems to be posted as an issue on nixpkgs on dotnet cannot find libX11.so.6.
This is the current shell.nix
I’m using for now (dotnet-sdk
is installed globally):
{ pkgs ? import ./pinned-nixpkgs.nix {} }:
pkgs.multiStdenv.mkDerivation {
name = "dev-shell";
buildInputs = with pkgs; [
libgdiplus
mono6
xorg.libX11
Any way to do a shellHook
so libX11 gets workings correctly? Or is this an issue with a missing 32-bit lib?
