I recently installed NixOS with gnome-wayland on a desktop, and sound usually doesn’t play, except if I open pavucontrol in a nix-shell. Then sound plays, but a few seconds after closing the window, the sound begins to glitch out then go silent.
It seems like pavucontrol is changing some routing that only lasts as long as the window is open. I tried checking the pacmd list-sinks and there are some differences while the window is open:
3 sink(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
- state: IDLE
+ state: RUNNING
suspend cause: (none)
priority: 9049
volume: front-left: 43245 / 66% / -10.83 dB, front-right: 43245 / 66% / -10.83 dB, rear-left: 43245 / 66% / -10.83 dB, rear-right: 43245 / 66% / -10.83 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
- current latency: 81.08 ms
- max request: 56 KiB
- max rewind: 56 KiB
+ current latency: 46.73 ms
+ max request: 27 KiB
+ max rewind: 27 KiB
monitor source: 0
- sample spec: s32le 4ch 48000Hz
+ sample spec: s32le 4ch 44100Hz
channel map: front-left,front-right,rear-left,rear-right
Surround 4.0
- used by: 0
- linked by: 1
- configured latency: 75.00 ms; range is 0.50 .. 1365.33 ms
+ used by: 1
+ linked by: 3
+ configured latency: 40.00 ms; range is 0.50 .. 1486.08 ms
card: 0 <alsa_card.usb-MOTU_M4_M4MA0A90BO-00>
module: 6
and then the rest is the same between them.
What might the issue be and how can I get sound to work reliably?
I have
sound.enable = true;
hardware.pulseaudio.enable = true;
in my config and my user is in the audio group.
