Speed up nix copy?
Hi, is it possible to speed up a `nix copy --to file://… $store_path?
An initial copy of a system derivation takes ~15 minutes here. While doing so, the nix (v2.4) process just uses 1 core.
  1. Is it possible to make nix use all cores for compression? I’ve tried the options core and max-jobs in ~/.config/nix/nix.conf. But, it looks like they behave as the documentation states and effect builds only and a copy/compression doesn’t count.
  2. Is it possible to change the compression or its level? Haven’t found any option for this.
Thanks, Daniel
Try this:
nix copy --to 'file:///tmp/cache/?compression=none&secret-key=/tmp/cache.pem' $store_path
Just opened the nix code and saw that there will be an additional “parallel-compression” and “compression-level” option in the next (?) release.
https://github.com/NixOS/nix/pull/2276
It’s in! Add compression level for NARs by tomberek · Pull Request #5372 · NixOS/nix · GitHub
nix copy was previously able to copy paths in parallel but that’s currently disabled (https://github.com/NixOS/nix/blob/52a3b2ee6367306a3f17fe9a2d0e2e4096852e05/src/libstore/store-api.cc#L940).
Why was it disabled? It’s not obvious to me from skimming over the commit message: Low-latency closure copy · NixOS/nix@fe1f34f · GitHub
