i got a problem with ssh login , the systemd service has the following message: Could not open user 'a4blue' authorized keys '/etc/ssh/authorized_keys.d/a4blue': Permission denied
Comparing with my machine, the permissions for /etc/ssh seem to be wrong. It should be 755, not 700. I tested by changing my /etc/ssh to 700. It causes the same issue.
just tested it, sadly it still says “Permission denied”.
I also tried switching between Nixos unstable and 23.11 and also between the default kernel and latest (had no effect)
I am now inclined to reinstall to see if it persists
Here is the log, i hope this helps, but i will now try to reinstall using nearly the same configuration
debug3: mm_answer_keyallowed: entering
debug1: temporarily_use_uid: 1000/100 (e=0/0)
debug1: trying public key file /home/a4blue/.ssh/authorized_keys
debug1: Could not open user 'a4blue' authorized keys '/home/a4blue/.ssh/authorized_keys': No such file or directory
debug1: restore_uid: 0/0
debug1: trying public key file /etc/ssh/authorized_keys.d/a4blue
debug3: mm_answer_keyallowed: publickey authentication test: ED25519 key is not allowed
Okay i think that i found the issue:
I had the folder /etc/ssh/ on chmod 0700, but after i changed it to 0755 it now works (bear in mind that the private keys need to be 0700)
Probably the logic was the following:
check / => allowed
check /etc => allowed
check /etc/ssh => permission denied, abort
but what i thought was follwing:
check /etc/ssh/authorized.keys.d/a4blue => allowed
or alternatively
check /etc/ssh/authorized.keys.d/ => allowed
find and check /etc/ssh/authorized-keys.d/a4blue => allowed
I will rebuild my system later this day again and see if this really was the problem
