\[\]\[\] \[\] \[\]nix-shell-env\[\] \[\] v2.1.1741730670\[\]
\[\][\[\]user\[\]@\[\]nixos\[\] \[\]nvim\[\]]\$\[\] nvim .
this is the prompt shell i get after entering a shell through direnv
# .envrc
use flake .#devShells.x86_64-linux.nix
use flake .#devShells.x86_64-linux.lua
You can try adding bashInteractive to the shell.
yes it is related but it doesn’t fix my issue, i’ve already implemented a workaround for this issue:
flake-utils.lib.eachDefaultSystem (system: let
pkgs = import nixpkgs {
inherit system;
config.allowUnfreePredicate = pkg: builtins.elem (pkgs.lib.getName pkg) ["intelephense"];
overlays = [
(final: prev: {
# mkCustomShellNoCC = prev.mkShellNoCC.override (oldAttrs: {
# packages = oldAttrs.packages ++ [pkgs.tree-sitter];
mkCustomShellNoCC = args:
prev.mkShellNoCC (args
packages = args.packages ++ [pkgs.tree-sitter];
shellHook =
(args.shellHook or "")
if [ -x "${pkgs.starship}/bin/starship" ]; then
case "$SHELL" in
*/zsh) eval "$(${pkgs.starship}/bin/starship init zsh)" ;;
*/bash) eval "$(${pkgs.starship}/bin/starship init bash)" ;;
esac
fi
so when i enter a devshell i evaluate this line eval "$(starship init zsh)" but when i added direnv, it no longer works
oh wait, the shellhook i added is what it was causing the problem lol, i should’ve known earlier, thanks guys for your help : )
