Hi folks.
i am trying to follow this wiki entry above. it seems i have no network when i create the container. I confirmed can create a shell inside the container but once inside i cant ping anywhere … can anyone suggest what is happening please ?
Here is what i did :
incus launch images:ubuntu/23.10 ub00 \
--profile default \
-c security.nesting=true
-→ incus profile show default
config: {}
description: Default Incus profile
devices:
eth0:
network: incusbr0
type: nic
root:
path: /
pool: store00
type: disk
used_by: []
-→ ifconfig
enp5s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.2.10 netmask 255.255.255.0 broadcast 192.168.2.255
inet6 fe80::7210:e505:ae22:ca8a prefixlen 64 scopeid 0x20<link>
ether 04:42:1a:f1:ee:4f txqueuelen 1000 (Ethernet)
RX packets 334937 bytes 431382673 (411.3 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 149980 bytes 12970338 (12.3 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
incusbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 10.252.113.1 netmask 255.255.255.0 broadcast 0.0.0.0
inet6 fd42:b8d8:ec7c:c832::1 prefixlen 64 scopeid 0x0<global>
ether 00:16:3e:b8:9e:a9 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 237 bytes 19838 (19.3 KiB)
TX packets 237 bytes 19838 (19.3 KiB)
