Steam problems on wayland
i am currently trying to set up steam on wayland and run into issues with xwayland-sattelite. the steam error message is:
steam.sh[519031]: Running Steam on nixos 24.11 64-bit
steam.sh[519031]: STEAM_RUNTIME is enabled automatically
setup.sh[519079]: Steam runtime environment up-to-date!
steam.sh[519031]: Steam client's requirements are satisfied
CProcessEnvironmentManager is ready, 6 preallocated environment variables.
[2024-12-24 22:09:02] Startup - updater built Dec  2 2024 21:26:10
[2024-12-24 22:09:02] Startup - Steam Client launched with: '/home/noof/.local/share/Steam/ubuntu12_32/steam' '-srt-logger-opened'
12/24 22:09:02 minidumps folder is set to /tmp/dumps
12/24 22:09:02 Init: Installing breakpad exception handler for appid(steam)/version(1733265492)/tid(519142)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2024-12-24 22:09:02] Loading cached metrics from disk (/home/noof/.local/share/Steam/package/steam_client_metrics.bin)
[2024-12-24 22:09:02] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2024-12-24 22:09:02] Using the following download hosts for Public, Realm steamglobal
[2024-12-24 22:09:02] 1. https://client-update.steamstatic.com, /, Realm 'steamglobal', weight was 1, source = 'baked in'
[2024-12-24 22:09:02] Checking for update on startup
[2024-12-24 22:09:02] Checking for available updates...
[2024-12-24 22:09:02] Downloading manifest: https://client-update.steamstatic.com/steam_client_ubuntu12
[2024-12-24 22:09:02] Manifest download: send request
[2024-12-24 22:09:02] Manifest download: waiting for download to finish
[2024-12-24 22:09:03] Manifest download: finished
[2024-12-24 22:09:03] Download skipped: /steam_client_ubuntu12 version 1733265492, installed version 1733265492, existing pending version 0
[2024-12-24 22:09:03] Nothing to do
[2024-12-24 22:09:03] Verifying installation...
[2024-12-24 22:09:03] Performing checksum verification of executable files
[2024-12-24 22:09:03] Verification complete
UpdateUI: skip show logo
Steam logging initialized: directory: /home/noof/.local/share/Steam/logs
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf609c840
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf609b000
steamwebhelper.sh[519150]: Using supervisor /home/noof/.steam/root/ubuntu12_32/steam-runtime/amd64/usr/bin/steam-runtime-supervisor
steamwebhelper.sh[519150]: Starting steamwebhelper under bootstrap sniper steam runtime via /home/noof/.local/share/Steam/ubuntu12_64/steam-runtime-sniper.sh
src/vgui2/src/surface_linux.cpp (1954) : glXChooseVisual failed
src/vgui2/src/surface_linux.cpp (1954) : Fatal assert; application exiting
12/24 22:09:04 Init: Installing breakpad exception handler for appid(steam)/version(1733265492)/tid(519142)
steamwebhelper.sh[519150]: Using CEF sandbox \(try with -no-cef-sandbox if this fails\)
steamwebhelper.sh[519150]: Starting steamwebhelper with Sniper steam runtime at /home/noof/.local/share/Steam/ubuntu12_64/steam-runtime-sniper/_v2-entry-point
assert_20241224220904_8.dmp[519193]: Uploading dump (out-of-process)
/tmp/dumps/assert_20241224220904_8.dmp
assert_20241224220904_8.dmp[519193]: Finished uploading minidump (out-of-process): success = yes
assert_20241224220904_8.dmp[519193]: response: CrashID=bp-2a1ca8e1-cdd7-42bd-a1ac-e45f02241224
assert_20241224220904_8.dmp[519193]: file ''/tmp/dumps/assert_20241224220904_8.dmp'', upload yes: ''CrashID=bp-2a1ca8e1-cdd7-42bd-a1ac-e45f02241224''
xwayland-sattelite doesnt give any relevant outputs.
does someone know whats going wrong? please help.
Do you have hardware.graphics.enable32Bit set? Steam requires a multilib setup.
now getting another error:
ok, got it working now. but the main window is completely black, but not the other windows (the friend window etc.). any ideas what this is about?
Nvidia on wayland with a driver version or compositor lacking explicit sync?
Try disabling “Enable GPU accelerated rendering in web views” in Steam.
That’s just a band-aid fyi. If nvidia is indeed the problem, you should switch to a more recent driver, and get a compositor that supports explicit sync (I think gnome does out of the box, and it looks like you’re using that).
Lack of explicit sync is just going to cause issues whenever you do want accelerated rendering afterwards, so basically anytime you actually launch something with steam.
somehow works now, dont know what it was. solved magically after ~20 rebuilds.
